Originally Posted by Pastorjaye
Hello ,
Travel Trailer newbie here. Sorry for the flood of silly questions.
1. When I dewinterie using city water, do I still need to fill and flush the fresh water tanK?
2. If I only plan to use city water and not Boonedock do I still need to fill and flush the white water tank?
3. Will it harm the camper to leave the antifreeze in the black and grey tanks until they are 3/4 full and ready to be emptied?
4. If I mess up and don't flush the antifreeze enough is the water still safe to use?
Thanks!
Jaye
Questions 1 & 2...
Yes you should even if you 'plan' to never use it.
It's always a good idea to carry at least a few gallons of water in the fresh tank for those unexpected potty breaks or washing of hands after a flat tire or Heaven forbid you break down and have to stay somewhere other than you 'thought' you were going to be that had hook-ups.
Also there's been times when in a full hook up campground that the power went out and they couldn't provide water. Having some water in the tank has saved us.
We also stayed at one park where they came around and said they were going to work on the water lines. We added water to our tank before they shut off the water and used our on-board pump. It didn't ruin the camping trip that way.
If you don't prepare in advance, you'll miss out on the opportunity to use it.
#3...
Nope... won't hurt a thing
#4... RV antifreeze is non-toxic. It won't poison you but it might taste funny or leave an oily type residue on your skin. It doesn't take much flushing to rid the system of the antifreeze and then you should sanitize your entire plumbing system anyway.
