Old 06-10-2013, 07:34 AM   #1
ryand's Avatar
Do not attempt to polish diamond plate
Just a word of warning- Washed the Camper this weekend and attempted to remove some stubborn bug guts on the diamond plate rock guard on my Coachmen with a metal polish....Guess this really is not a true diamond plate rather a thin sheet of i would assume aluminum over plastic?? Anyhow the polish scratched it all to hell and i ended up going ahead and "Polishing" the entire panel. Now I have a Brushed aluminium Rock guard.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 06-10-2013, 07:58 AM   #2
Herk7769's Avatar
Sorry to hear about it.
Any chance a cloth buffing wheel and rouge will get it back shiny?
HAM CALLSIGN - KC3FFW
Old 06-10-2013, 08:00 AM   #3
ryand's Avatar
Possibly....If anything it might make the "haze" a bit more uniform.
Old 06-10-2013, 08:10 PM   #4
10x
I waxed my camper and Diamond plate with no issues. Maybe its something in the polish you have?
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 07-20-2013, 10:48 PM   #5
What polish was it ?
zzzzzzz is offline   Reply With Quote
Old 07-20-2013, 11:01 PM   #6
wmcclay's Avatar
Try mothers alum polish. Its a lot of work but worth it.
Wayne and Donna
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 07-22-2013, 11:21 AM   #7
ryand's Avatar
I used a SS polish i used to use for cleaning exhaust tips on motorcycles and such. Looking back it was a bit abrasive. I am going to wax it and see if it brings back the luster.
Old 07-25-2013, 07:30 PM   #8
Thurman's Avatar
Once you polished the area did the area you polished look as if the bright diamond plate had come off and underneath that there was either a white-ish or black-ish looking surface? IF so--then you may indeed have an aluminum coated plastic sheet. There are coatings for plastic that will appear as nice as new chrome, and there are so-called "polished Diamond Plate" sheets out there. One way to tell for sure is to take a paper clip, straighten it out, heat one end of it up really hot and stick it straight into the material. If it appears to melt a hole into the material then is is plastic. Of course if nothing happens then it may indeed be a metal plate. This surface could even be black sheet metal diamond plate which has had an aluminum powder coat applied and polished well.
Thurman is offline   Reply With Quote
Old 08-23-2013, 04:56 PM   #9
It can be polished if it is indeed aluminum. I would recommend a product called Flitz, it is the best I've found in 28 years of polishing the aluminum on my rig. Second choice would be Zephyr 40. If your really gung ho and want a mirror finish use a 5000 rpm angle grinder and a yellow buffing wheel with red bar of rouge as a start and finish with a white wheel with the green bar of rouge.
These will all work providing your diamond plate isn't "protected" with some kind of sealer.
mrtrdrvr is offline   Reply With Quote
Old 08-23-2013, 04:59 PM   #10
daydreaming about camping
jeeplj8's Avatar
our current trailer does not have diamond plate, but our last one did. The diamond plate had been sprayed with a coat of clear coat.
Even if the aluminum coat is thin, it seems unlikely you could have worked through it by hand.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
