Old 09-02-2018, 02:12 PM   #1
Does anyone make RUBBER bumper end caps?
It seems that the Camco bumper caps are no longer available in rubber. The plastic one now are a pain, they have to pounded in with mallet and are hard to get back out of the bumper.
I looked on Amazon and saw some that claim to be rubber but I hate to find they are really plastic.
John Mcg
John McG is offline   Reply With Quote
Old 09-02-2018, 02:16 PM   #2
Hi,
I gave up on the caps long ago.
Instead, I drilled two vertically aligned holes about an inch in from each end of the bumper. Found two aluminum tent pegs a few inches longer than the bumper is thick, straightened them a bit into a kind of "L", and dropped them in the holes. A nice barrier to the hose slipping out either end, which also allows ventilation and drying for the hose.
My two cents...
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 09-02-2018, 02:22 PM   #3
Rich,
Not a bad idea, have to consider this.
John
Old 09-14-2018, 05:43 PM   #4
I have also seen magnetic ones.
NCScott is offline   Reply With Quote
Old 09-14-2018, 05:51 PM   #5
Originally Posted by richp View Post
Hi,
My two cents...
Rich Phillips
You went "top drawer". I did the same on my 95 Terry. Drilled the holes but used a couple of 1/4" bolts from Home Depot. Gravity held them in place and I suppose if I wanted more security I could have drilled them for hitch pin clips. If one is afraid of their hose being stolen they make a long shackle padlock that will fit the 4" tube with room to spare. Just drill the holes accordingly to fit the shackle.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 11-15-2018, 08:50 PM   #6
I drilled holes thru the bumper & end caps and used driveway reflectors to secure them. Click image for larger version
ID:	191526 Also provides a safety feature for the rear end.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 11-16-2018, 06:27 PM   #7
There was a guy on ebay that was selling a aluminum hinged door for the bumpers.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 11-16-2018, 06:52 PM   #8
The magnetic caps work great and connect to your sewer hose so you don't have to go fishing for the hose and they are cheap.
https://www.amazon.com/Camco-40311-M...mper+cap&psc=1
Okmechanic is offline   Reply With Quote
