Old 06-15-2017, 10:13 AM   #1
Carknocker Family
Ida Ratherbe Camping's Avatar
Dometic 300 toilet trouble
Seems as though my Dometic 300 toilet has finally started the dreaded stink feast.
I remember when I purchased TT that alot of people were having trouble with the 300 having a defect and we're getting replaced with the 310 for free under warranty.
I didn't have the problem, so I did not pursue. (My problem was the Dometic 15k a/c.)
Now 4 yrs later, it stinks! So my question is, has anyone had trouble with the replacement 310?
Fixing to buy one and looking for reviews.
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 06-15-2017, 12:33 PM   #2
When mine started the stink I had the seal changed. I was already going to the dealer to get the A/C changed out (warranty) and they said it only took a few minutes. Have not had a problem since. I would be willing to bet there is a YouTube video that would walk you through changing it yourself.
T1109d1 is offline   Reply With Quote
Old 06-15-2017, 04:23 PM   #3
Carknocker Family
If it's just a seal on the ball, I can find that part. But if it's this problem , i have not been able to find any of the parts needed on the net.
http//www.forestriverforums.com/forums/f217/dometic-model-300-odor-problem-and-replacement-43509.html
Thanks again
2017 Ram 2500
2014 Salem 32BHDS
Old 06-16-2017, 06:04 PM   #4
Call Dometic with the model & serial number of your toilet. It is on a tag at the rear of the toilet by the floor. Your camera phone comes in handy here. I had mine replaced by the recall. By this time they were replacing them with "re-engineered" model 300 units. Had the replacement sent to the campground in Colorado I was going to. Took about 30 minutes to remove and install the new 300 toilet. Just 2 nuts mounting it to the floor and disconnecting the water line to it (turn water off first). New foam seal came with it. Have had no problems with new one.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 06-17-2017, 12:29 PM   #5
DouglasReid's Avatar
Our camper is 5 years old and just began to smell in the bathroom. Along with the odor, the toilet no longer was able to hold water above the ball valve.
The fix was incredibly simple, a new rubber seal solved both issues. I think around $29.00 (WAY overpriced for a rubber gasket, I KNOW) but it popped right out, and the new one popped right in. BOTH problems solved in less than 5 minutes
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 06-17-2017, 04:28 PM   #6
this is a good excuse to upgrade to the 310.....the porcelain bowl is much better than the plastic, and it's an easy job. But as mention earlier call Dometic with the SN#....they may send you a 310 to replace it with.
danc is offline   Reply With Quote
Old 06-17-2017, 05:43 PM   #7
Carknocker Family
The bowl is holding water, so I don't believe my odor is coming from tank. It get worse if we turn on fan.
I have had toilet off before, froze water valve. Totally my fault and easy to fix.
Will try to call Dometic Monday and see what they say.
2017 Ram 2500
2014 Salem 32BHDS
Old 06-17-2017, 06:01 PM   #8
Wobbles's Avatar
How long will it hold water? I had a like problem. Turns out that when using a wand to spay out the tank I bumped the ball and un-seated one of the two arms of the ball.
I was told to pour water in and give it 10 to 20 minutes to see if the water went past the seal. Sure enough the was was gone after a few minutes. Put on the rubber gloves, reached down and popped the second ball arm back into position. Solved my problem but not the one where I wanted the 320 model. lol...
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 06-17-2017, 06:14 PM   #9
Carknocker Family
This last trip, we were camping 10 days. Never had bowl not have water in it.
Smell was worse, after set up, then stopped after a couple days. Then we changed sites, smell came back. So I believe I have liquid between halves and movement of camper is sloshing it around. Starting the problem over again.
When I dumped black tank, I backwashed extra preparing for toilet removal. Was stinking again when we arrived home. Water still in bowl.
2017 Ram 2500
2014 Salem 32BHDS
Old 06-17-2017, 06:16 PM   #10
Wobbles's Avatar
a 310 is in your future then... Had I not fixed mine, I would have one...
Bob & Michelle
Old 06-17-2017, 08:05 PM   #11
BeachBowen's Avatar
Had the same problem, had my 300 replaced with the remodeled 300 last year only to have the same issue again. Dometic will not warranty a warranty replacement so I bought a 310. What ever you decide which I recommend the 310, take the top half of your 300 off and you will see where the smell is coming from. The rubber seal between the two halves has moved and allowed sewage to collect in the pockets between the two halves.
BeachBowen is offline   Reply With Quote
Old 06-17-2017, 08:08 PM   #12
kgbarne's Avatar
The 310 is an awesome improvement over the 300. We went 3 years with the 300 and couldn't fix the smell no matter how much we cleaned. Discovered the defect issue on this forum. Had the 310 installed and no more smell!!
Moyock, NC Carolina Panther Fan!!!
2018 Puma 23SBC Toy Hauler;
2014 Ford F150 XLT 4X4
2002 EZGO Golf Cart
kgbarne is offline   Reply With Quote
Old 05-23-2018, 05:27 PM   #13
Life Without Whine's Avatar
Cannot believe I have had such a hard time digging out this thread over the past 5 years and we camp 9 out of 12 months every year with the odor issue first rearing its UGLY head in Nov 2013.
Emailed picture from under the peddle & our new toilet is on the way!!!! May want to post some sort of notice on FRF to make the tag to these threads easier to find. Obviously I had looked for the wrong things for tooooo long
Terri + Joe + BrewDog Boont
Camping a long weekend every month since starting in May of 2013 in order to practice for retirement .... Florida is a great state to have this bad habit
Life Without Whine is offline   Reply With Quote
Old 06-06-2018, 04:57 PM   #14
We also have the 300 toilet with odor issues. I emailed them Monday, gave them the serial number and they are sending me a new one.
Does anyone know how long it takes to receive the new toilet? Would like to have it next weekend for the next camping trip. Thanks!!
fortwilderness is offline   Reply With Quote
Old 06-07-2018, 04:17 AM   #15
We did have a problem. The clue ws that the toilet was no longer holdding a small amount of water above the flush valve.
I replaced the rubber seal...............problem solved
Old 06-07-2018, 05:22 AM   #16
NH Maple Maker
russhd1997's Avatar
Mine wasn't holding water and a new seal didn't fix it because the ball was deformed. The dealer installed a new toilet at no charge to me last fall. My TT is a 2014 so the warranty had expired long ago. I didn't know that there was a recall on them.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is offline   Reply With Quote
Old 06-12-2018, 08:39 PM   #17
Less than a week & we had ours .... just got back from our first trip with the new throne & the lack of smell was F-A-B-U-L-O-U-S !!!!!
Old 10-11-2018, 08:38 PM   #18
Thumbs up Stinky Toilet
Our Dometic 300 was 1 year old when it stunk badly. We contacted Dometic and they were wonderful about replacing it (They have a two year warranty). They had us provide the serial number and asked us if we wanted to upgrade to the 310 with a porcelain bowl and self closing lid. The upgrade was less than $100. We did not have to ship the old one back and the rep suggested we steal the water valves off of it. So happy.
tgsmith is offline   Reply With Quote
dometic
