08-16-2018, 03:30 PM
Drivers license
PA requires a “non commercial” class A license for a combination where the towed vehicle is over 10000 and the combined weight is over 26001. Anyone else have one of these???
08-16-2018, 08:28 PM
Happy Keystone Owner
Illinois
Class A — Combination of vehicles with a GCWR* of 26,001 or more pounds, providing the GVWR of the vehicle being towed is in excess of 10,000 pounds.
Class B — Single vehicle with a GVWR* of 26,001 or more pounds, or any such vehicle towing another not in excess of 10,000 pounds.
Class C — Single vehicle with a GVWR* of at least 16,001 pounds but less than 26,001 pounds.
Class D — Single vehicle with a GVWR* of less than 16,001 pounds.
*GCWR — Gross Combination Weight Rating
*GVWR — Gross Vehicle Weight Rating
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
08-16-2018, 08:38 PM
Originally Posted by dbarr
Illinois
Do they make a distinction between commercial and non-commercial??
08-16-2018, 08:44 PM
Coach
As long as your combined gvw is under 26001 lbs a class C is adequate in PA to my knowledge. What are the gvw's of your truck and trailer?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
08-16-2018, 08:47 PM
Truck GVWR IS 11500. RV GVWR is 16000+. I’m close to 28000 combined GVWR which puts me in Class A non-commercial territory.
08-16-2018, 08:57 PM
Virginia requires a standard drivers licence for non commercial towing no classes.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
08-16-2018, 09:07 PM
Same numbers for both.
2014-47,
Years camping....55
08-16-2018, 09:27 PM
Coach
That's definitely class A territory. I reread the PADMV license classes and your original thought of towing anything over 10,000 gvwr does seem to constitute class A.
08-16-2018, 09:37 PM
Who Dares, Wins
Yep need a class a. It is the same test as for a cdl class a. The problem is finding the correct dmv center that can do the class a test. Last person I heard trying to get one on here had to make many phone calls before he found a dmv that even new there was a class a... Then even longer trying to find a place that does them. For the test you'll also need someone with a class a or class a cdl to bring you to the test.
2015 Chevy HD D-Max
2022 Impression 315MB
08-16-2018, 10:04 PM
I have gone thru this in Illinois and the Classes show in dbarr messages are only for commercial CDL type driver licenses. I know this to be a fact because when I moved here I tried to secure a Class A non CDL license. The secretary of state office in Springfield il said there is no such thing in Illinois as a Class A non CDL license. So I was going to secure a CDL but the secretary of state said that for a personal use RV all that was required was a normal drivers license and that is a Class D. I have been driving my F350 and fifth wheel in Illinois now for many years with a normal drivers license.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
08-16-2018, 10:14 PM
Finding someone I know with a class A will be the hardest part. There are a bunch of local trucking companies here. Might be able to pinch somewhere there...
08-17-2018, 09:04 AM
Who Dares, Wins
Yes I can imagine so. It can be a class a or cdl class a person. No class b folks.
2015 Chevy HD D-Max
08-21-2018, 07:44 PM
I have a Class B Non Commercial drivers license. I obtained the license when I had a motorhome. It is not hard to obtain. You need to study the PA CDL learners manual. Any PA DMV driver license and photo center can administer the test. You should call the center to make sure an officer will be available to administer the test. You will need to have the vehicle or vehicles (truck and trailer) for the road test. You also need to have a licensed driver with an equal or greater license than the license you are seeking. The examining officer checked his drivers license before he did anything with me. I did not need to take a written test only the road test. I was asked several questions about the vehicle such as air brakes and this led to more questions. If you study the CDL learners manual, you will have no problems. The road test was a piece of cake. A Tip -- make sure you do not have a tire hit a curb. That is a sure way to fail the test.
I highly recommend the appropriate class drivers license for the vehicle(s) you operate. If you are involved in an accident, your insurance company may require it. I notified my insurance company when I obtained my class B license. They thanked me when I did.
Dave
08-21-2018, 07:54 PM
Who Dares, Wins
Don't bet that all dmvs can do the cdl test.. They cannot around here.
If you are stopped as well the insurance company will be the least of the issue at that time.
Edit: I said cdl test but meant the a and b drive test.
2015 Chevy HD D-Max
08-21-2018, 08:04 PM
Camper
In NYS, regular class D license covers a vehicle with a GVWR or 26,000 lbs or less and tows a trailer with a GVWR of more than 10,000 lbs provided the GCWR is 26,000 or less. An R endorsement is needed for a RV with a GVWR over 26,000 lbs. A CDL is not required.
Change made in 2005
Changes for Drivers with Current Class D Licenses.
A driver with a Class D license can now operate a passenger vehicle, a limited use automobile, or:
- A truck with a gross vehicle weight rating (GVWR) of 26,000 lbs. or less. (Before, a Class D driver could only operate a vehicle with a GVWR of 18,000 lbs. or less.), and
- A truck with a GVWR of 26,000 lbs. or less that tows another vehicle, and the other vehicle has a GVWR of 10,000 lbs. or less, and
- A truck with a GVWR of 26,000 lbs. or less that tows another vehicle that has a GVWR of more than 10,000 lbs., but the gross combined weight rating (GCWR) of the two vehicles together must be 26,000 lbs. or less.
A driver with a Class D license can now operate a personal use vehicle (for example a rental vehicle or a recreational vehicle or RV) with a gross vehicle weight rating (GVWR) of 26,000 lbs. or less that tows another vehicle that has a GVWR of 10,000 lbs. or more, but the gross combined weight rating (GCWR) of the two vehicles together must be 26,000 lbs. or less.
https://dmv.ny.gov/commercial-driver...lass-c-license
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
08-21-2018, 08:26 PM
I’m told Harrisburg or Chambersburg. For me that will be Harrisburg...
08-21-2018, 08:28 PM
Who Dares, Wins
I do believe someone else had posted about getting theirs in Harrisburg
2015 Chevy HD D-Max
