Old 06-07-2012, 08:19 AM   #81
(Kim)
Labzy's Avatar
Originally Posted by TF-Kevin View Post
We were camping at Bow Valley an hour west of Calgary, there was a young couple who rented a trailer that was set up next to us, The owners of the trailer did not empty the tanks when they rented it out , When they used the shower it started to back up. So the young fellow figured that he will empty the tank himself, and all he had was a small garbage can, which he filled and started walking down the road, asking where is the dump station, which it was 7 kms away, That look on that poor guy face was so sad, So i lend him my portable waste tank, i felt so sorry for him and his wife, But i have to admit it was funny to watch him carrying that garbage pail down the road.
That was mighty nice of you to help him out.
I bet that he would have walked about 2-3km (depending on the temp) before his arms and/or back and/or willpower gave out, causing him to dump it alongside the road.
That was your good deed of the day
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 06-07-2012, 08:25 AM   #82
MilCop4523's Avatar
Blue Boy? what is it other than a blue tank?
Cost and best place to get one... Different sizes?
Like I've said I've had to bag my own stuff out after a week long exercise but carrying it in a pail down the roadway... OMG
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is online now   Reply With Quote
Old 06-07-2012, 08:45 AM   #83
Travelin Man
I have one of those caps on mine that has a hose connection on it, so if you have some fluid in the pipe you can open the cap and have the hose ready to catch it. sure beats having a 3 inch pipe full of fluid coming at you. I like the idea of adding another valve in case you ever get any leaks. I also have a clear connector so I know what is in the pipe before I open it.
Douglasdh62 is offline   Reply With Quote
Old 06-07-2012, 01:59 PM   #84
FreedomTracker's Avatar
I usually just keep the black tank valve open when I open the gray tank valve and finish the dump process.
Is there any reason to close the black valve BEFORE opening the gray valve? Personally, I don't think it makes any difference... just curious.
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 06-07-2012, 02:18 PM   #85
Herk7769's Avatar
Always the potential I suppose to suck some solids out of the black tank that will then stay in the main plumbing after you are done draining the gray.
HAM CALLSIGN - KC3FFW
Old 07-02-2012, 04:06 PM   #86
Ft W crew's Avatar
Make sure valves are closed before removing cap! And stand to the side when opening valves:
Remove cap and connect sewer hose:
Open gray valve to make sure connections are good (just enough to fill sewer hose and test for leaks). If you have a bad connection at least it is gray water. I also believe the soapy water probably makes a good lubricant/coating on the inside of the hose.
Close the gray with water still in tank and open up black tank. Using a clear elbow you should be able to tell when it is empty. If you have a black flush, using a separate hose (mine is actually a gray coiled hose) connect and flush for 5 minutes with valve open. Once you are done flushing, close black water valve and finish dumping gray. Disconnect flush hose from RV and use to rinse the sewer hose and area.
This system has worked for me for years with no gloves. I keep antibacterial soap next to sewer connections so I can wash my hands right afterwards.
I also recommend replacing the sewer hose every couple of years with a high quality one. I found the rhino hoses work well. The environment will also dictate however often to change hose. I got lucky when I got done dumping, of course with my system it was gray water at this point the hose split, how it did not split during the dump is still a surprise too me
My worst experience was camping with no hook ups for a two nighter. There were a bunch of teenagers around and they apparent went around at night pulling all the black water valves they could find. Luckily I noticed mine was open prior to removing the cap. I only noticed because the guy in front of me did not, and he ended up with some blue and brown suede shoes. I closed the valve and used a stick from the side to open valve directly over dump station only the small amount that was between the valve and cap escaped. Ever since then I always check to make sure the valves are closed prior to taking cap off.
2012 Freedom Express Liberty Edition 292BHDS
2011 GMC Yukon XL 2500 4X4 (what a difference)
2007 Ford Expedition EL Eddie Bauer 2WD (sold)
Ft W crew is offline   Reply With Quote
Old 07-02-2012, 05:39 PM   #87
great white's Avatar
I pull up, snap on latex gloves, hook up to the built in flush lines, hook up dump hose, open black, drain, turn on flush hose, let it run a bit, turn off flush, close black, open grey, close gray, disconnect dump hose, spray flush hose down dump hose, install caps, store it all, flip gloves in garbage can and get the heck out.
Pretty simple.
Never had a problem.
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 07-02-2012, 11:20 PM   #88
WestCoastRV'er's Avatar
Couldn't believe my eyes today when I pulled into Rasar State Park in Washington. The guy ahead of me was dumping his gray and black water directly onto the ground at the dumping station. Thought to myself, this is strange. Took a photo of the guy and license plate of the trailer. Gave this information to the local Ranger. After the guy was finished he took every effort to not step into the mess he left.
Before using I poured a mixture of water and bleach and hosed the best I could into the dump drain.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 07-23-2012, 02:46 PM   #89
punkaccountant's Avatar
I was at a state park last week and witnessed a family wash their kids (with bathing suits on) and dog at the dump station using the supplied water hose. You could hear the clanking as they were tripping on the sewer cap. I would have said something but the dad didn't look like he wanted to be told anything. YUCK!!!
http://www.forestriverforums.com/attachments/signaturepics/sigpic20864_3.gif
2013 Rockwood Mini-Lite 2306
2011 Ram 2500HD Hemi
punkaccountant is offline   Reply With Quote
Old 07-23-2012, 03:04 PM   #90
Herk7769's Avatar
Double Yuck...
led pad
