Old 01-06-2019, 07:09 PM   #1
Dynamax Isata 4 2019
3 month anology of Isata 4 ownership!
Picked up our 2019 Isata 4 in Elkhart Indiana. Almost 3 months later than promised by the dealer. I suspect builds for the dealers wishing to display new models at the Hershey PA RV show took precedence. Canít prove this.
Drove it home to Pennsylvania. No problems except screws laying on the coach floor. The fuse panel, membrane push button station for the slide out, touch screen interface all stripped. Power tools will do this on 1/8 inch panelling.
The rear view and turn signal cameras stopped working. Water ingress on the turn signal cameras shorted the in-line fuse. Location of the fuse was a bear!
Power mirrors stopped working. This is still an issue. Though not a big one.
The slide out stopped working. Had to re-program the in/out sensors.
Half of the coach lighting would not work! The circuit board was locked up. Had to do a hard reboot. This meant removing the 12 volt supply wire directly from the circuit board.(must be done gingerly)
The top hinge for the screen door has no screws.
Re-seated two of the window screens. The screen was doing nothing on two of the corners.
The rubber trim for the coach floor. Had to re-screw in several places that simply were not anchored.
Not bad for a three month old dream Motorhome.
Iím sure I missed a couple of incidents. But still plan on enjoying our new coach.
Limey1071 is offline   Reply With Quote
