Old 06-02-2013, 08:04 AM   #1
wayne in florida's Avatar
Easy Stabilizing project Completed
Mind you I did not think of this it was on a post I seen some time back. Credit is due to that member, and I Thank You!!!!
I needed something like this due to the ground clearance the OEM stabilizers must make up anytime I setup my PUP. Im a firm believer (May not be a fact) but the less the jacks are extended the more stable your camper will be. So with the basic concept I seen in the Photos from that post I went out and got a treated 2x12x10 cut this into 8 equal lengths 15 each. Marked the cutout notches (Centered 7.5) and on a table saw cut them out. I made this cut to fit tight as I suspect the wood will dry and shrink some and finished the cuts with handsaw... The next part needed to be done with a wood chisel. Finish cutting the notch out and take your time to get this cut correct as the two boards must fit correctly to get the max support. A little trimming and coat of paint will come once the wood dries. Done!
ID:	31969   Click image for larger version
2006 Dodge Ram 2500 5.9 CTD
2012 Flagstaff MAC BR28TSC
2012 Days camped 23
2013 days camped 16
wayne in florida is offline   Reply With Quote
Old 06-02-2013, 08:15 AM   #2
By the looks of the lower left (Turbo) must have helped you! Nice job. Youroo!!
Old 06-02-2013, 08:23 AM   #3
zs325RES's Avatar
Great concept.
You are correct - the less you extend the OE jacks, the more stable your setup will be. I proved that out with a simple 4" change last weekend. Made a big difference.
Thanks for sharing.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider, Air Lift bags & Black Bear Performance tune & CAI
zs325RES is offline   Reply With Quote
Old 06-02-2013, 08:25 AM   #4
One more thing.......I will use a 2x6 on top of the X for a platform for the stabilizer Foot pad.
Youroo.....Only one thing better then a cold beer......2 cold beers.
2012 Days camped 23
2013 days camped 16
