07-12-2015, 08:26 AM
Easy Trick to Removing Bugs From Front of RV
We've all had the front end of our RV covered in bug guts and parts. The best way to remove them? Try dryer sheets! Here's a quick video which shows their effectiveness:
https://youtu.be/P2AGzJjJViI
Happy Cleaning!!
07-12-2015, 08:41 AM
Location: Alberta - East of the Rockies, West of the Rest
Thanks for sharing, I'll have to try that trick right away .
2018 RAM 5500 Laramie CC
Sold: Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Ordered: 2021....
07-12-2015, 09:03 AM
07-12-2015, 12:36 PM
This works I have used this on the front of my Ram and Wildcat. The cheap ones work just as well as bounce.
1967 Barracuda fastback
2015 Wildcat MK 333
2010 Ram 2500 Mega-cab
07-13-2015, 09:28 AM
Here's what I do with our 5th wheel. I learned this years ago trying to get bugs off my motorcycle windshield. I droop a large shipping blanket over the front. Then I hose down the blanket so it's completely soaked. Make sure that the blanket is in contact with the fiberglass. Crack a beer, have dinner and go to bed. Over night the wet blanket has softened everything up. Pull off the blanket and hose off the bugs. No rubbing at all.
07-13-2015, 09:43 AM
I know it sounds crazy, but Dow Scrubbing Bubbles Bathroom Cleaner is the best stuff I've ever used.
I just mist some water on the front cap, and out of direct sun, spray the Bubbles on. Let it sit for 5-10 minutes and then I just scrub em off with a soft bristle brush on one of my extention poles. Takes em right off. If they've been on awhile do it a second time.
Dosen't hurt the fiberglass, or glass, or paint.
And, as a side benifit, it also removes black streaks!!!
Grumpy
07-13-2015, 12:48 PM
I have been using this method on my cars in Florida and it just eats the love bugs right off the car. I haven't had occasion to try on my fifth wheel yet but I will before the summer is over. (Dryer Sheets)
Richard Charron
Zephyrhills, FL
2015 Ford F150 Eco Boost
2016 Coachmen Chaparral Lite 29MKS
07-13-2015, 12:53 PM
Search "getting the bugs off" & you will find a lot more info on this topic.
07-13-2015, 01:34 PM
What I need to know is how to get up there safely to clean the overcab.
Linda
Solera 24R
Washington
07-13-2015, 02:17 PM
Bugs off
Been using dryer sheets for awhile, works great. I always apply a new coat of wax on the cap each time too.
07-13-2015, 02:47 PM
If anybody would like to come over and show me how to do this on my motorhome, I would provide a Coke! Heck, I would even splurge for beer!
07-13-2015, 04:03 PM
What has worked for me, is spraying unscented Pledge! Yes the furniture cleaner. Apply it on before I leave on a trip and let dry.
When I return home just water hose it off, bugs and grime come right off.
Just my 2cents on the matter.....
07-13-2015, 07:47 PM
I tried the dryer sheets, but they did not work for me. I have the clear plastic protective film on the front of my motor home. I do not recommend the plastic. Once it is penetrated by big bugs, stones, misc. road debris, etc., it looks bad.
Note on the Scrubbing bubbles: I love the stuff, but it discolored the black plastic on the mirror housings of my car, so I no longer use it.
A good coat of "303 Protectant" after a complete wash really makes cleaning and bug removal much easier the next time.
07-13-2015, 08:22 PM
I highly recommend "Awesome Orange". (I keep wanting to call it "Agent Orange.") It's a non-abrasive liquid that "softens" the little dried-on critters. Used it on my 5er last year (before I got a Class A) and found it works great. It's $1 at the Dollar Tree.
2018 Berkshire 38A
07-14-2015, 06:34 AM
I am guessing emason83 is right on !!!
If are going to use anything like that,,,
you will need to re-wax !!!
A good coat of wax helps to make it easer next time !!!
07-14-2015, 06:49 AM
Georgia Rally Coordinator
A friend of mine in FL pointed me to using the dryer sheets and he does not even own a camper Really work well. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-17-2015, 10:52 AM
Hydrogen peroxide works great. Use and rinse off.
07-18-2015, 05:51 PM
I've had good results with dryer sheets too.
07-18-2015, 07:30 PM
Phat Phrog Stunt Crew
My RV dealer hooked me on Orange "Crush" cleaning solution for the bugs and black streaks.
2014 Wildcat 327ck
07-19-2015, 05:07 AM
SD 20 is also a very good product to use around the house,,,
Of course it will all so remove the Wax !!!
