Old 10-10-2015, 07:51 PM   #1
Rodgers's Avatar
Electric water heater use.
Got a problem need help water heater won't light may be low on gas using stove so don't think it is want help with info on switching to electric is a 2011 Sierra with a suburban water heater SW10DE. I pulled the pin and flipped the switch. Is that all I need to do or do we still use the lighting switch inside to get it to light or does it just start to heat from the switch flipped outside. It's been awhile since we used the electric part.
Rodgers is offline   Reply With Quote
Old 10-10-2015, 08:00 PM   #2
Ford Idaho's Avatar
Both switches need be on.
Old 10-10-2015, 08:04 PM   #3
If you only have one switch inside then you only have to turn the outside switch on.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 10-10-2015, 08:19 PM   #4
wmtire's Avatar
This FAQ may help you remember in the operation of the Suburban brand of water heater:
Suburban's electric switch and much more
A quick question though. Have you used your water heater this year? Many times people forget the bypass valves are still in the winterization mode and the water heater is empty, but since the water heater is bypassed with the cold and hot water lines tied together, they get water out of the taps but it's not coming from the water heater.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 10-10-2015, 08:39 PM   #5
Rodgers's Avatar
Thanks all that really helped we do have hot water will check gas tomorrow.
Old 10-10-2015, 08:48 PM   #6
The switch inside the camper is for the propane side and the one outside in the wh compartment is for the 110v side. They are 2 independent ways the wh will furnish hot water and DO NOT BOTH need to be on at the same time to get hot water. They will RECOVER faster with both on, but will work perfectly fine on either electric or propane.
Old 10-10-2015, 09:30 PM   #7
IchLiebeBier's Avatar
During our last trip, I couldn't get the gas to come with the electric on at the same time. After reading the manual again, I now think the gas will only come on if the water is below a certain temperature. A thermostat will keep the DSI from igniting the gas.
So if you are trying to get the gas to work just to test it, test it cold.
If I'm wrong anyone, please correct me, so I'll understand it better.
2019 Heritage Glen LTZ 272RL
2018 Ram 2500 CTD
IchLiebeBier is online now   Reply With Quote
Old 10-10-2015, 09:35 PM   #8
wmtire's Avatar
You are correct, The propane side and the electric heating element side BOTH have thermostats that control their prospective side. If the water is already hot due to the electric heating element, then the propane will not fire up as there is no need to.
However, when you are showering or using a lot of water quickly, and have both sides switches turned on, then when the water temp drops inside the heater, then the propane will fire up, as well as the heating element coming on....up until the thermostats preset temp is reached...then the thermostats will cut power to their prospective sides.
Propane fueled fire heats the water quicker than the electric heating element.
Old 10-11-2015, 12:46 PM   #9
dicky1243's Avatar
You are correct, we use the elect all the time and occasionly add the gas when the temp dips below 30*
PS don't leave the elect on if you drain the water heater in between camps
2006 Gmc
2016 Forestriver Sierra 376 BHOK
Full Timers
Dick,
dicky1243 is offline   Reply With Quote
Old 10-11-2015, 04:07 PM   #10
Boss Hoss's Avatar
I'm with him
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
electric, heater, water, water heater
