Old 09-23-2014, 01:48 PM   #11
I have an bottle jack that is part of the pickup plus another 12 ton jack.
I see everyone using trailer aids etc, why wouldn't you just roll your good tire up on a few blocks (lynx etc)?
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 09-23-2014, 02:11 PM   #12
themounties's Avatar
We had a blowout on our way home from Goshen, made several attempts to get the good tire up on the lynx levlers but it would not go up on them, was not a fun time, I'm gonna look at these trailer aids but not sure, they show the wheels farther apart then mine.
themounties is offline   Reply With Quote
Old 09-28-2014, 03:34 PM   #13
Capsfloyd's Avatar
Trailer Aid works very good with tandem axles. I carry a bottle jack too
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 10-05-2014, 10:24 PM   #14
How big of a bottle jack to I need for our 18.5ft Wildwood x-lite?
laurarice26 is offline   Reply With Quote
Old 10-05-2014, 10:35 PM   #15
asquared's Avatar
I used the trailer aid on my old tt. It didn't work, the tt flexed and kept the other wheel on the ground. Had to go back to using the hydraulic Jack. This has gotten me thinking that the current fiver is probably too heavy for my current Jack. Guess it's time to go shopping.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 10-05-2014, 10:53 PM   #16
X2, but Trailer Aid Plus (touch taller), and a unijack (jackstand bottle jack combo unit). Just a tip - make sure you measure various clearance points along your trailer and ensure whatever jack you purchase will fit accordingly.
rana is offline   Reply With Quote
Old 10-05-2014, 11:22 PM   #17
Probably any you find would work but for a technical answer, take the manual's published weight for the camper and figure you might have all of it on that axle. What is the answer, 3 tons?, pretty reasonable size jack. Don't forget to carry enough pads to put under it to get the tire off the ground! In fact if this is a single axle and the tire is flat the reach of the jack might let you get the flat off the axle but not have sufficient stroke to put the inflated spare on the axle. You better figure out how to handle that problem before worrying about the size of the jack. It is easy, does not require a second jack but requires more than asking a message board about the size jack needed.
Timtation is offline   Reply With Quote
