Old 03-08-2008, 09:32 PM   #1
Cyber Phrenologist
Radio's Avatar
Enamel v Aluminium v Stainless Steel
I tip I learned back in the backpacking days:
Of the three materials listed (for cook pots) stainless steel requires the least amount of water to cleanup. Perhaps of interest only to the boondocker as RV parks generally have an abundance of clean water in comparison to places I have backpacked into.
Easier generally means faster, and that's important too, especally when it's my night to do the dishes.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 03-09-2008, 12:00 AM   #2
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
what about cast iron? I bet you don't backpack with a lot of that, huh??
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 03-09-2008, 11:04 AM   #3
Cyber Phrenologist
Radio's Avatar
No, but I discovered if you pour water into a cast iron skillet while it's still hot, as in right after you finish cooking, a lot of the grease and such will break free and float on the boiling water which can then be dumped. Sometimes it does sucha good job all you need to do is swab out the skillet then with paper towels. Saves water on clean up. Works better on some food than others.
KU4OJ
Old 03-09-2008, 02:22 PM   #4
The Jolly Mon
NDJollyMon's Avatar
I've also heard that doing so could crack the cast iron? I'll have to research that one a little more. Memory sometimes...what was I saying...
Pete (Jolly Mon)
