Exterior 3 burner Gas Cooktop hookup?
Im sure this is a simple question but I don't know the answer. I have a cast iron 3 burner cooktop that I hook up to a 5 gallon propane bottle. It has its own adjustable pressure regulator. The regulator is very handy because it adjusts the flame better than the brass ball valves the cooktop has on it.
I also have a quick connect fitting just below the propane bottle on the right side of the camper. It is providing low pressure gas after the changover regulator. Can I hook up to the low pressure from the camper to the cooktop's regulator and get reliable gas from the camper or would I have to remove the adjustable regulator that is currently on the cooktop?
Thanks in advance for your help
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
