Old 06-09-2014, 09:21 PM   #21
Originally Posted by OldCoot View Post
If you put the first coat of white, you could then paint it another color that pleases you. The base of white will be what reflects the heat and the subsequent color would be of your choice. Bottom line, who looks at vent covers anyway? Paint would sure look better than stuffing a pillow, foil or anything else.
Good point. I will try it on some of the other vents. Any particular brand of paint? Does it need slightly sanded and primered first? I would look at the vents. I look at everything
OKI Marine is offline   Reply With Quote
Old 06-09-2014, 09:25 PM   #22
Originally Posted by Mark S View Post
My new camper came with a skylight over the shower. The heat coming through was unbearable. I Velcroed aluminum foil insulation to the underside and that helped but the heat still came through the skylight.
I then sprayed the top/outside of the skylight with white Plasti-Dip. The difference was dramatic. I no longer needed the insulation. I get light but no real heat coming through.
white Plasti-Dip? What is it ? Who makes it and where do you get it? Does it go on the inside or outside? Expensive?
Old 06-09-2014, 09:26 PM   #23
I made a cover for the bathroom skylight which works great and protects the skylight also.
Old 06-09-2014, 09:32 PM   #24
Ford Idaho's Avatar
Auto Zone or O'Reilly carry it.
Pick a color.
It is made for plastic.
Spray Paints | MSCDirect.com
Old 06-09-2014, 09:36 PM   #25
Paint the inside so it is not exposed to the elements, etc.
Old 06-09-2014, 09:44 PM   #26
Mark S's Avatar
www.plastidip.com/
Plasti-dip is a spray paint like rubberized coating. Sprays on like paint but turns into a sheet of rubber or plastic. It can be peeled off. Apparently has insulating properties.
I bought at Home Depot for about $7. Sprayed the outside of skylight about 4 or 5 times. So far it's working great.
Mark and Joanne
2014 Fun Finder XT 276
2015 Ford F150 Lariat 3.5 Ecoboost 4X4 SCrew Max Tow
2011 Harley Road Glide Ultra
Mark S is offline   Reply With Quote
Old 06-09-2014, 09:58 PM   #27
ironj's Avatar
my bath skylight was totally clear.....and let in waaaayyyy too much heat and light in the summer....so i used the spray someone mentioned before for plastic tail lights..(VHT Nightshades).its designed for plastic and is a translucent coating....basically spray on tint....works well when you still want light in.....otherwise i would use a base of krylon for plastic in white or two, then a couple of coats of black.....i didnt want ALL the light blocked out.....just most of it...lol
Sent from my Transformer Prime TF201 using Forest River Forums mobile app
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 06-10-2014, 11:49 PM   #28
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Exactly, VHT Nightshades was the name of the spray and every additional coat makes it a shade darker but be careful with accidental overspray.
Same with Plasti Dip only that it can be peeled off later, the effects are dramatic (and it is relatively inexpensive). I even use it on tool handles to get a better grip, it feels kind of rubbery.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is online now   Reply With Quote
Old 06-11-2014, 05:11 AM   #29
BamaBob's Avatar
You can get Plastidip at Lowes or Home Depot.
You really should cover all your vents (even though it sounds like the one in question has a rain sensor.) Camco makes a very reasonably priced one - just as good as the Maxxair IMO - here is a link to the cover on Amazon:
Amazon.com: Camco 40431 Roof Vent Cover (White): Automotive
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
cover, fan, vent
