Closed Thread
Old 11-25-2019, 02:11 PM   #1
DavidJ's Avatar
Filling LP tanks
Here is a very rookie question. I looked in the thread referring to LP tanks but did not find the answer.
On our TT, we have two 33 gal LP tanks. There is LP in both tanks, but I would like to top them off. When I go to an RV Park, Camping World, a gas station, wherever, do I have to disconnect and carry the tanks to the filling station, or can they fill them with it connected to my TT?
Is this decision based on law, the dealer, or what?
I know this is a very general question, but I have only had our tanks filled once. And we had to disconnect and carry to the filling station. I have an injured back and would prefer not to disconnect.
thanks
David & Cindy in Iowa
2017 RockWood 2504S travel trailer
2015 Chevy Silverado 1500 LTZ
DavidJ is online now
Old 11-25-2019, 02:19 PM   #2
Depends on the filling station.
Typically, they should be removed and then the filler puts them on a scale and weighs them when filling.
Some places don't care and if their hose is long enough, they will simply ask you to pull near enough to attach the hose and pump LP until the meter stops.
You really should get in the habit of removing your tanks to get them filled and then you won't be disappointed when they ask you for the tank and fill it the right way.
Oh and BTW... I'm guessing you have two 30 POUND tanks and not two 33 GALLON tanks!
And also... depending on the filling station... some only charge for the amount that goes in the tank when topping off and other places charge a flat fee based upon tank size no matter how little it takes to top it off.
Days Camped: '17=30 '18=51 '19=58 '20=21
5picker is online now
Old 11-25-2019, 02:49 PM   #3
wmtire's Avatar
Howdy rookie (your words)
This thread may help, and even has a link about refilling and exchanging propane cylinders.
New to RV's helpful hints
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
wmtire is offline
Old 11-25-2019, 03:28 PM   #4
jd50i's Avatar
unless they are completely empty, without putting them on a scale you will be charged for a full tank no matter how much was still in it.
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
jd50i is offline
Old 11-25-2019, 03:41 PM   #5
Not always...
I just had three filled today. (2-20# and 1-30#)
All three had varying amounts left in them.
None of them sat on a scale during filling and I was only charged the combined gallonage on the meter once all three were filled.
Old 11-25-2019, 03:44 PM   #6
cboss's Avatar
Smile
Fill them at Tractor Supply. They only charge for what you need and they might even carry them back to your truck for you. Also, their price is always competitive.
Craig & Cath
2018 2902WS Rockwood Ultra Lite
2017 Ford F250 Lariat, 6.2 gas
Equalizer Hitch w/ 4-Point Sway Control
Days camped since 2016(retirement): 750
cboss is offline
Old 11-25-2019, 03:47 PM   #7
jd50i's Avatar
Not always...
I must frequent primitive places. All of them used scales, I didn't see a flow meter on them. My ignorance
2014 Grey Wolf 21RR
jd50i is offline
Old 11-25-2019, 04:17 PM   #8
Every place I have been to measures out in gallons but they use the scale to know when they are full.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline
Old 11-25-2019, 04:32 PM   #9
Not really a true statement . depends on the where . out west lots of places sell by the gallon . i find very few if any use scales anymore . since the 80% shut off was mandated they just open the bleed valve till it starts to come out . anyone that sells by weight is a rip off as are the exchange a bottle .
MR.M is offline
Old 11-25-2019, 04:35 PM   #10
thanks
Depends on where you go if you can get close enough and they have a long enough hose you can get them filled without removing them . i don't believe there is any law preventing it since motor homes have tanks that can't be removed and are filled in place on the unit so if they fill motor homes there then can most likely accommodate you
MR.M is offline
Old 11-25-2019, 05:30 PM   #11
Flybob's Avatar
Think the best answer is to call the facility where you plan to take them and ask. If it is a full service propane distributor you chances of only being charged only for a partial full are higher. Should also be prepared to transport them in an upright position as some facilities will not fill them if you are transporting them lying on side.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Flybob is offline
Old 11-25-2019, 06:00 PM   #12
Between two TT's dating back to 1995 I have never had a tank weighed. On my trips I merely pull up to the dispensing station, pull the tank cover, remove pigtails, and say "fill er up".
Only time I have had to remove the tanks is when I take them off at home and take them to be filled. The ONE exception was at a KOA in Ellensberg WA where the park attendant asked if he could just take the tanks from my site, fill, and return, as if I parked at their dispenser I'd block the entrance.
Since the advent of OPD valves the value of using a scale has been greatly negated. Perhaps some local regulations still remain in the dark ages but none that I've encountered in a dozen States I've traveled through.
To add, my tanks are clearly marked that the use of the "spit valve" is even optional now that OPD's are installed.
As for paying a flat rate, not where I buy propane. If that's their policy I move on.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is online now
Old 11-25-2019, 07:00 PM   #13
I top off mine at an Ace hardware store, ( popular on east coast) and they have both a scale tanks sit on and are gauged by pds put in. My tanks last throughout summer, so I can’t say for other places that fill tanks
dodgemark is offline
Old 11-25-2019, 07:34 PM   #14
Minthillbill's Avatar
Depends on where you go.
My place fills and I pay for what they put in. By the gallon.
And I take my tanks off.
When a tank expires (12 years). I exchange at Walmart for $15. For a 20 pound tank with 17 pounds in it.
2016 rockwood premier 2516G
2008 wildwood le 19BH
Tv 2018 F150 screw 3.5EB
Retired UNC Charlotte engineering professor.
Minthillbill is offline
Old 11-25-2019, 08:09 PM   #15
You said , " top them off ", most of the time one should be full and you are pulling from the other , Most TTs have an auto switch over regulator with an indicator to indicate which one is empty .
wanderingbob is offline
Old 11-25-2019, 08:15 PM   #16
That's how it works on mine too. Yes, I know which tank is empty but when I go to get them filled (while on the trailer) I want the other tank "topped off".
2004 Nissan Titan
Old 11-25-2019, 08:15 PM   #17
The place I go to usually(U-Haul) used to always fill until the liquid came out the bleed screw and then you just paid for the gallons delivered to the tank. They claim regulations changed and they are no longer allowed to open the bleed screw so they weigh the tanks to tell when they are full. They still only charge for the gallons delivered.
babock is offline
Old 11-25-2019, 08:25 PM   #18
Chances are that there is no local reg requiring use of the scale but u-haul is just applying one that affects a couple of their stores somewhere else in the nation to ALL locations.
Around here nobody uses scales and fills purely through the meter. Some still open the outage valve but most just fill until OPD shuts off.
Seems like it's all over the map on this.
What's amusing is when I was at Quartzsite last January and bought propane at the RV Pit Stop they operators filled 20 and 20# tanks still on the trailer tongues and tanks that were off the vehicle they just used the scale for a place to set the tanks. Nobody bothered to even look at it's readings.
2004 Nissan Titan
Old 11-25-2019, 08:53 PM   #19
SlowrideHD's Avatar
Got one of my 30 lb tanks filled today, which was empty. I had a 20 lb tank in a grill that felt like it had maybe 1/4 to 1/3 left in it. The date on the 20 lb tank was 11/09 so the cert on it will run out the end of this month.
Got them filled at my local u-haul store that does not weigh...they just charge for gallons pumped through the meter. 10.4 gallons was $36.28 ($3.49/gal)
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline
Old 11-26-2019, 02:39 PM   #20
wmtire's Avatar
Our local tractor supply does it properly and uses the scales to ensure it's correct on the portable DOT cylinders.. Pics taken about twenty minutes ago when I went to get one refilled for Thanksgiving turkey frying.Click image for larger version
ID:	219891Click image for larger version
Geaux Tigers!!!!
wmtire is offline
Closed Thread
tank
