Old 05-08-2011, 08:38 AM   #1
Captain Ron's Avatar
Filling the fresh water tank without a direct hookup?
When you get to a site and don't have a water spigot nearby what do you use to get water into the fresh water tank?
I have a 7 gallon rolling water jug that is great for getting the water to the TH, But there is no way to pour the water from that jug into the fresh water tank fill opening. Are there suggestions for a funnel or something that you've used to make this easier?
Thanks!
...ron
2011 Wolf Pack 19WP
2015 Ford F250 XLT CC SB 4X4 6.2L 3.73
Captain Ron is offline   Reply With Quote
Old 05-08-2011, 09:20 AM   #2
We have used a small funnel and placed our 7 gallon jug on a table prompt up and let the water trickle in so we didn't have to hold it.
Worked out pretty well
Happy Camping!!
Sam & Mary
2015 Columbus 320rs
Samary is offline   Reply With Quote
Old 05-08-2011, 12:07 PM   #3
flyrotor's Avatar
I use the blue 6 gallon jugs you can get at Walmart and sporting goods stores with a white cap, the cap has a threaded spicket that is plastic, cheap and breaks easy, I bought a brass threaded water spicket at HD and hook a short hose to it, prop it up on a table and stick the hose in the trailer filler, I carry two of the blue jugs and just switch the lid when transferring to the trailer
flyrotor is offline   Reply With Quote
Old 05-08-2011, 12:21 PM   #4
I generally use some or all of the 250 feet of water hose I carry just for that purpose. We have been known on occasion to use over 500 feet of water hose to fill our tanks.
Old 05-08-2011, 12:31 PM   #5
I don't think I have room for that much hose
Thanks for the suggestions so far!
...ron
2011 Wolf Pack 19WP
Old 05-08-2011, 01:11 PM   #6
Herk7769's Avatar
I use the Blue plastic jugs too. I made an adapter to a Vinyl hose out of an old cap. I was using the big 6 gallon jobs, but now I use 4 of the 3 gallon square ones. They fit better on the folding hand cart I use and are less painful to lift.
Put the hose in the gravity fill port and up end the jug.
The small hole in the cap only goes through the white plastic and not the inner seal foam. That way it will "bubble" all around the foam and not leak so much.
ID:	5665   Click image for larger version
ID:	5666   Click image for larger version
HAM CALLSIGN - KC3FFW
Old 05-08-2011, 01:17 PM   #7
flyrotor's Avatar
I forgot to add..... there's not a lot of sense in carrying 40 or 50 gallons of extra water because your holding tanks are limited.
Unless you have ability to dump your holding tanks into portable holding tanks to take to the dump station.
Old 05-08-2011, 01:19 PM   #8
Send a message via Skype™ to scubieman
I used a funnel from the automotive isle at walmart. It has a built in screen to catch debris before going into the way tank.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 05-09-2011, 08:32 PM   #9
cheese53073's Avatar
we've used a drill operated pump and a 110 volt pump to fill our friends trailer tank. I'm thinking of installing extra piping/vinyl hose and either using my demand pump or adding a second 12v pump to fill my tanks.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 06-08-2011, 11:11 AM   #10
Hal
Born 2 Camp
I purchased a 63 gal tank for my truck bed and refill from that using a 110v pump hooked to my generator, in the middle of nowhere on a deer lease. I know that Northern Tool (and I'm sure others) have a 12VDC transfer pump available, and the Titan has a 12VDC outlet inside the bed, so that may be a handy option too.
If you want to do smaller amounts or avoid powered pumps, you may want to look for one of the self priming siphons and just mount the jug on a table, high enough to let gravity help once you get it started. Northern Tool also has those (at least locally), and I believe that they cost less than $10. They make it easy to start - just drop it up and down a couple times to prime, and off you go.
Hal is offline   Reply With Quote
