This tread has got me planning and plotting my own fire starters. Good mental exercises when I need a break at work.
I've been accumulating dryer lint, toilet paper tubes and stray 1/2 burned candles. With the 1/2 used bag of match light in the garage I'm hoping to make a nice batch of fire starters.
I'm thinking of putting a briquet in the center of the toilet paper tube. Stuff lint on both sides, then crimp close. Pour wax over the tube to wet it and then dry.
I'm going to build some this weekend and test them out.
Thoughts?
Make sure you add a fuse and yell "fire in the hole" before lighting them. Then run. Your family and neighbors will love you for it!
This may sound crude but i just keep a one gallon can of diesel for lighting the fire, works well and a lot cheaper than fire starter fluid. Pour some of that on top of the logs, let it soak in a bit and then light it. Does not flash like gasoline does.
2013 Wildwood 29BHBS
2009 Toyota Tacoma
The crew;
DG, DH
Tally the Greyhound and Itty the Chihuahua
We also use the dryer lint, egg carton and I use all the left over citronella candle wax. We tried using Belly Button Lint, but DW thought it was rude when I kept asking the campers to pull their shirts up....whatever!
C'mon lighten up Life is to short to be a grumpy pants!
I watched my first fires started and "fed" by gasoline recently. That was "interesting"...
We still get a weekly local paper and the local and Seattle Sunday ones. I prefer to read them in a leisurely fashion, in an arm chair with a glass of beer or two to help things along. Reading everything on a computer screen gives me eyestrain.
Frank and Eileen
No longer RVers or FR owners
