Old 07-09-2016, 06:38 AM   #11
mrpep's Avatar
Got it , thanks guys - just seemed kind of weird cause I didn't get this with my van but then again I am hauling much more weight now Adays.
mrpep is offline   Reply With Quote
Old 07-09-2016, 06:49 AM   #12
RSchleder's Avatar
Your tow vehicle is performing exactly like it should. If it did not shift down to a lower gear which cause's the RPM's to rise, the engine would lug and the transmission would be in the incorrect gear causing excessive heat which is your transmission's worst enemy! Just enjoy and let the electronic "brain" in the transmission do it's thing, it's designed to keep the engine and transmission in sync, don't try to out guess it!
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 07-09-2016, 07:00 AM   #13
mrpep's Avatar
Ok thanks , I actually thought the electronic brain was on drugs when it did this , lol - also, I swear I could see the gas needle drop when it revved that high, lol
Old 07-09-2016, 07:41 AM   #14
Mr. Dan's Avatar
We would still like to know the answer to MillerTime's question: what year is your Yukon Denali?
Those 6.0L engines are known to burn some gas. My son has one in a Yukon Denali. His username on another forum is Gasguzzler!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 14; booked = 28
Old 07-09-2016, 08:45 AM   #15
mrpep's Avatar
2003 and when towing I used 7.5 mpg
Old 07-09-2016, 08:51 AM   #16
Mr. Dan's Avatar
Our son's unit is also a 2003.
Old 07-09-2016, 09:12 AM   #17
Oklahoma Proud
MillerTime's Avatar
I think alot of those Denali's were all-wheel-drive back then. That will contribute to the lessened mpg.
I bought an escalade wrecked a few weeks ago, i think its a 2002 or 2003 with the HO. 6.0. Its Awd and i only drove it around 50 miles home.
The DIC showed it got 14.5 mpg with aftermarket exhaust on it and empty. I did notice it shifting alot, but i thought it was due to reduced back pressure from the aftermarket exhaust . I already have a stock muffler to put back on it to try to regain the back pressure needed to keep it in the torque area a little better w/o shifting all the time.
Old 07-09-2016, 09:42 AM   #18
mrpep's Avatar
I get 14.5 in town as well , it's just towing and I just bought this specifically for towing , lol
Old 07-09-2016, 11:33 AM   #19
Completely normal! It'll eat gas when it downshifts and holds higher rpms. Seems like it's doing what it's supposed to. Mpgs seem right. Maybe not the best TV but it'll do.
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 07-09-2016, 02:15 PM   #20
Casino Camper
jughrad's Avatar
You should actually try to leave it in the high RPM gear the whole time and not let her shift so much. My Denali has a manual shift capability and I leave it in a single gear on hills.
You should have a digital readout of your transmission temperature. You will notice that it stays cooler when you are running higher RPMs.
You need to keep that transmission temperature below 200 degrees. With lower RPMs you are probably not getting a full converter lock on your transmission and the clutch may slip under load.
That 6.0 L engine is designed to operate at 4000 RPM with no problem. Your transmission is not capable of operating above 200 degrees without damage.
jughrad is offline   Reply With Quote
first time, towing
