Old 09-28-2018, 06:52 AM   #1
SeaDog's Avatar
Fixing Problems
It struct me this morning while having coffee and reading the forum if you step back and look at the big picture with slides, jacks, stabilizers, remotes, lights etc not working the common denominator is often the house (coach) batteries. My advice when yo have a problem before jumping to the hard stuff check the batteries first. If you're plugged in and hit the test switch you are testing the converter un-plug and then hit the test button (or use a meter) and see what you get. This easy check can solve allot of hand wringing and teeth gnawing and time wasted. Just something to consider.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
