Old 01-13-2019, 11:00 PM   #1
dcheatwood's Avatar
Ford key fob programming.
Here's a little tip some of you may already know about. About 15 years ago I found a Ford key fob with a few keys in a mall parking lot.
Not sure why I held on to them so long. Guess I was hoping the owner would magically appear to claim them.
But after recently buying a Class C Forester with the Ford E450 chassis I got to looking into the possibility of making that key fob work on the new E450. A quick check on YouTube turned up a simple technique for programming Ford fobs. I tried it and Shazam! I now have a third working key fob for the RV.
If you have an old fob lying around, check it out. Took about a minute to do it.
2018 Forester 3011 DS
Old 01-13-2019, 11:19 PM   #2
You have the link? If so please post.
Gonefishing1 is online now   Reply With Quote
Old 01-14-2019, 08:04 AM   #3
Keystoner's Avatar
It's good that you already had two working fobs. I needed a second fob/key but could not program it without going to a Ford dealer. Two working fobs are required for non-dealer programing additional ones.
Keystoner is offline   Reply With Quote
Old 01-14-2019, 08:49 AM   #4
RV There Yet?
IsleDog's Avatar
I dont believe that i had to have 2 keyfobs when i programmed mine. I transferred on from my previous 1998 expedition to my current 2009 F150. the procedure is below. I want to say I used the first set of directions, took maybe 2 minutes to do. since i have memory seats, each keyfob moves the seat to that drivers set position when unlocking the doors.
http://www.keyfobprogram.com/ford-ke...nstructions-1/
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is offline   Reply With Quote
Old 01-14-2019, 08:56 AM   #5
For keys you have to have two existing, fobs doesnít matter.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 01-14-2019, 02:17 PM   #6
My wife lost her car keys for the Infinity and a locksmith duplicated it (chip) ..Why would you need a dealer?
LI Guy is offline   Reply With Quote
Old 01-14-2019, 02:19 PM   #7
I was talking about programming keys on your own on a Ford.
Old 01-14-2019, 08:53 PM   #8
SailorSam20500's Avatar
Another nice capability. For those with keyless ignition. Your vehicle can be programmed so that you can't move the gear shift unless the fob is inside the vehicle. Some vehicles are programmed that way. On ones that aren't you can request the change from your dealer or do it yourself. To make this change and others on Ford vehicles, check do a search for FORSCAN. You need a diagnostic reader tool that costs about $30 and a windows based laptop. Everything else is free. I've turned off the horn honk that the engine is running and drivers door ajar with engine running sounds. Figured other folks in campgrounds really didn't want to hear my trucks nanny notices while I hitched up - especially if it was early in the morning.
Al
Save the Earth. Itís the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 01-15-2019, 12:57 AM   #9
For keys you have to have two existing, fobs doesn’t matter.
You need two fobs to program another. They don't want someone to use a lone fob to program another in case someone like a valet has one of them.
I just ordered 2 spare fobs for my truck. Cheap insurance. My truck has push button start. Super easy to program.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 01-17-2019, 09:17 AM   #10
I don't think you need 2 FOBs to program a new one.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
ford
