Old 02-28-2019, 07:31 PM   #1
Drew
Forester 2401 MBS
Looking for alternative storage for sewer hose. The built in one is very short (less than 2 feet) and does not accommodate a hose with fittings at both ends (really Forest River, who would have thought we would put fittings at both ends?) I do not have a square rear bumper like I had one my TT, so no way to store it in there. Currency using a plastic tote in one of the exterior storage compartments, but would like to store it outside somewhere. Tried HD and 4' plastic pipe (largest they had), but ID is not big enough for fitting.
OregonForester is offline   Reply With Quote
Old 03-04-2019, 07:25 PM   #2
larry2c's Avatar
Lots of folks have gone this route - uses 5" vinyl fence post with a vinyl rain gutter inside for a sliding tray. An easy DIY and it holds the hose and fittings.
Name:	Sewer hose 1.jpg
ID:	198103   Click image for larger version
Name:	Sewer hose 2.jpg
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
Old 03-04-2019, 10:03 PM   #3
Drew
I have a piece of 5" vinyl fence post. Is this mounted on a Forester MBS? If so, how is it attached to the frame?
Old 03-04-2019, 11:12 PM   #4
larry2c's Avatar
No, we have a Cruise Lite travel trailer and it is mounted to the frame of the trailer with "L" brackets purchased at good ole Home Depot. I'm not sure if you could hang it off of your coaches frame or not. Maybe you could mount it to the existing rear bumper? I have seen these hose holders mounted in many different ways on TT's and motorhomes - you'll just have to find the spot that works for yours (ground clearance, etc.)
'11 F150 5.0
Two shedding mutts
forester
