Old 08-01-2010, 08:34 PM   #1
Fresh tank fill / City water fill
New member, New RV and very green trying to learn before our first trip. What is the difference between the City water fill and the Fresh tank fill?
Thank you
Bryantaa is offline   Reply With Quote
Old 08-01-2010, 08:35 PM   #2
milzat's Avatar
Originally Posted by Bryantaa View Post
New member, New RV and trying to learn before we head out on our first trip. What is the difference between Fresh Tank Fill and City Water Fill?? Do I fill both what do each do? Thank you
Fresh tank fill: The fresh water tank is filled using a garden hose(or waster supply hose). The 12 volt on-board pump supplies water to kitchen sink, shower/tube, toilet and water heater.
City water connection: Supplies water to same, by-passing the fresh water tank.
milzat is offline   Reply With Quote
Old 08-01-2010, 08:39 PM   #3
Thank you for your quick reply. So I use the City water when I'm hooked up at a camp ground?
Old 08-01-2010, 08:41 PM   #4
If you are going to a campground that has water at your site, then there is no need to fill the fresh water tank. You simply connect your hose to the city water connection and to the campground faucet. Not carrying your water will cut down on the weight you have to tow.
If, however you are going to a site that has no water hookup (usually many national parks do not have any hookups at all), then you will need to fill the fresh tank.
Hokiehall is offline   Reply With Quote
Old 08-01-2010, 08:42 PM   #5
I understand now. Thank you
Old 08-01-2010, 08:50 PM   #6
One thing you should consider do when using the fresh water tank and camper has sat for awhile is to sanitize it. Bacteria can build up in there and if your tank sours, you can get sick.
Pappytx is offline   Reply With Quote
Old 08-01-2010, 08:53 PM   #7
milzat's Avatar
Or Home Brew.
Right Kim ???
Old 08-02-2010, 05:00 AM   #8
Originally Posted by milzat View Post
Or Home Brew.
Right Kim ???
Old 08-02-2010, 06:34 AM   #9
camping
tentcamper1's Avatar
use a pressure regulator when hooking up to the city water. welcome to the forum, enjoy the trailer.
with all the talk about home brew I might have to head to Virginia!
2007 Chevy 2500HD CC
2010 V-Lite 30WRLTS
Nights Camped 2011 -64
Nights Camped 2012 -50
"I Live in My Own World, But It's OK. They Know Me"
tentcamper1 is offline   Reply With Quote
Old 08-14-2010, 07:52 AM   #10
MrT
MrT's Avatar
Or Michigan...
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
Old 08-14-2010, 08:33 AM   #11
Originally Posted by MrT View Post
Or Michigan...
Do a tour and hit both.
