Old 09-20-2014, 06:16 PM   #1
davel3083's Avatar
Fresh water fill on new campers
Good afternoon everyone, need to ask a question, had a older camper that had a fresh water fill, by removing a cap and dumping water into the tank and could be added when needed. Well that being said, just bought a brand new camper and find out the water fill is now done by a water hose that needs to be pressurized to fill the holding tank. Well what happens after I fill the holding tank and I pull into my camp site and I need to add water to holding tank, I carry a water jug but I can't add water because it won't take it, please someone tell me what I am doing wrong and how to fix the situation, I would like to camp in state park for more than a few days, but I will run out of water and have no way to add more...
davel3083 is offline   Reply With Quote
Old 09-20-2014, 06:32 PM   #2
Ford Idaho's Avatar
https://www.google.com/webhp?tab=mw&...=rv+water+pump
Buy a water pump, bolt it to a plywood board, with enough wire and a set of
ProgressiveRC - FMA Alligator Clip to EC5 Cable
Use the battery of your tow rig to run the pump.
You can pick up the needed hose fittings at Lowes or Home depot.
Old 09-22-2014, 07:56 AM   #3
mrmichael's Avatar
Most I have seen have a hose connection to provide pressure when connected to a water supply, and a fill spigot the fill the fresh water tank that you would use your onboard pump for. Yours might be different
Other Motorhome
2013 F-150 Eco-Boost V6
mrmichael is online now   Reply With Quote
Old 09-22-2014, 08:33 AM   #4
davel3083's Avatar
I do have that set up, but after you fill the fresh water tank, let's say you are camping for 4 days, if I run out of water, I have no way of refilling without packing it up and pulling to a water fill station and filling with a hose, the older type had a cap on it and you could fill a 5 gallon bucket and dump right into holding tank, new one has to have water pressure behind it to refill, so I guess I will be rigging up a pump on a board and connecting to the battery and suck it out of the jug into the tank, thanks for all the replys....
Old 09-22-2014, 08:44 AM   #5
camper1999's Avatar
This is what i did to resolve that problem. It works great and is a lot easier then the water jugs.
ID:	63292   Click image for larger version
2011 GMC 2500HD Diesel
camper1999 is online now   Reply With Quote
camper, fresh water, water
