Old 06-26-2011, 01:34 PM   #1
Timex's Avatar
Friction Sway Bar
I've had a Reese friction sway control for 12 years, it's still works. BUT, I've had problems the last 2-3 years with the grunting, groaning, etc it makes when I make the slightest turn. My new V-Lite got looks from the "residents" as we drove into the rv park. Boy was I embarassed by the noises coming from that sway bar. Sounded like a whale singing underwater! I know it is the sway bar that is making the noise for I have disengaged it and the noise quit. My dealer suggested pulling the bar totally out and scrubbing it with steel wool and then thoroughly cleaning with spray brake cleaner. I've done all that. Didn't help. Is there anything else I can try or am I in the market for a new one?
Timex is offline   Reply With Quote
Old 06-26-2011, 01:56 PM   #2
Triguy's Avatar
Nature of the beast, I'd say. My current Equal-i-zer does the same thing. And it pops, too. Helps to grease the hitch ball and arm sockets on mine. But the noise is still there. Tells you its doing its job.
You get used to it and other campers know exactly why, too. Nothing to be embarrassed about.
If its late evening or early in the morning, however, I usually like to disengage the bars to keep the peace. No need for sway control in the CG.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 06-26-2011, 05:14 PM   #3
Timex's Avatar
I need to clarify. It is a Equalizer brand friction sway control. It didn't make all the sound effects when it was new. Of course, I didn't either!
I am a grease junkie. I grease my hitch ball, equalizer bars at the hitch point, and the balls where the sway control attaches. Then everytime I touch something for the next 10 years I have to wipe grease off.
Old 06-27-2011, 07:31 AM   #4
yvesm's Avatar
When I had a friction type sway control I use to take it off when I pulled in to the campground (at check in). That way I did not have to worry about making real sharp turns while backing up, I have seen these things bend when they get over extended.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 07-22-2011, 02:33 PM   #5
Weight distribution arms
My dealer didn't say anything to me about greasing my hitch, weight distribution or sway bar connections. I bet that would help with all of the popping and creaking though! Thanks!
I have noticed some grooves being scratched into the weight distribution arms where they fit into the hitch... Anything to worry about?
Thanks,
Chuck
Chuck
2016 Puma 30RLIS
2011 Catalina 19RD - totalled by hail
cbenslay is offline   Reply With Quote
Old 07-22-2011, 03:39 PM   #6
BigDTx's Avatar
So this is not an EQUALIZER Hitch? because there are no balls for the sway control to attach to on an EQAULIZER Hitch, so you must have a friction sway control added on to a regular hitch? can you post some pics? the friction type controller you have may be wearing and causing the noise. My EQAULIZER hith only has one ball and it is the tow ball????
BigDTx is offline   Reply With Quote
Old 07-22-2011, 04:31 PM   #7
Timex's Avatar
I agree, with no pics it may be hard to understand my problem. One of my next investments is going to be a digital camera!
Everytime I would make even a slight turn it would sound like a whale grunting and groaning. I know it is the sway control that is making the noise for I have disengaged it and the noise quits. My wife tells me I am OCD about noises, rattles and the like. She says just turn the radio louder to drown out things. Doesn't work. At least not on her! The sway control is still functional after 12 years but maybe it needs to be retired. I recently bought a new REESE friction sway control from CW. Haven't had a chance to use it yet to see how things go.
Try to picture a small hitch ball next to my big ball on the hitch that the hitch coupler connects to. The sway control connects 1 end to this small ball and the other end connects to another small ball mounted on the frame of the trailer tongue. The sway control is held onto the small balls with a clip type pin. I have my sway control on the passenger(curb) side for no real particular reason other than that was the way it was originally set up. And the hitch itself has an offset specifically for the sway control ball on this side. Also, my plug(for the lights,brake) and the breakaway cable is on the driver's(street) side of the setup. It is the last thing I hookup. I was told to rotate(tighten) the lever clockwise until snug, then to back off counterclockwise about 1/8 to 1/4 turn. Hope this explains things a little.HAPPY CAMPING!!!!
Old 07-22-2011, 04:41 PM   #8
BigDTx's Avatar
OK GOT IT, you have an ad on sway control with the little ball next to the tow ball on your receiver. They all make noise to some extent, I think they get on a slight bind and do not slide as freely as they should at times. if you have cleaned the slider and the sleeve it goes into then there is not much more you can do, IF you lube it then you will loose your sway control as it is a friction type controller. If it is bothering you and you just can't stand it, try out the new one you have from Reese it should solve your problem. CHEERS!
Old 07-22-2011, 05:24 PM   #9
cheese53073's Avatar
I have a brand new equalizer hitch (2 months old pulled only 5 times). it creaks groans and pops all the time. this is normal and tells you its working properly. even when I had the TT at the dealer it was popping and groaning. Not a word was said about it by them service manager or the 3-4 techs workinbg in the yard. Others may look at you but perhaps they are in awe of your set-up instead of annoyed by some noise. If the noises of a working hitch bother them then they may not be a true RVer.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 07-22-2011, 07:59 PM   #10
Hmmm... I have the same set-up, but I was told to tighten it with "2 fingers" and then tighten it a little more to where the bar you use to tighten it is horizontal. The Tech did say that is just how he does it...
Chuck
2016 Puma 30RLIS
