Old 05-03-2011, 06:57 PM   #1
vasnipe's Avatar
Fridge fan alternate
Hi guys, I got this idea from the forum thread on the refrigerator fan others have purchased off of eBay. I’m a bit “thrifty”, OK, call me CHEAP. I’ll squeeze that nickel so hard the buffalo burps. I’ll see something and try to figure out how to do it myself or find somewhere on this wonderful web thingy where someone else has already done the grunt work and then go for it. I found a similar hard drive cooling fan setup on Deal Extreme dot com at $3.95 - Dual Fans Hard Drive Cooling Attachment - Hardware Parts for all of $3.95 and free shipping. Not bad, but you can’t be in a hurry to get the thing… Anyway, it arrived in about 10 days and I pulled the connector plug off and put it away for some future use. I added the additional positive wire and soldered the spade connector on. I soldered the ground wire to the alligator clip and flattened it for drilling. I opened the second alligator clip, flattened and drilled it also. I drilled the fan flange (where it rounds over then flattens out) and used sheet metal screws I had on hand to connect the alligator clips to the fan housing. We took a trip to Pigeon Forge, TN this past weekend and it worked like a charm, no frost, no ice, and the fridge was colder than you know where. I’ll need a longer run to figure out where the “thermostat” needs to be set. Anyway, with 2 alligator clips the fan did not budge in position, despite the potholes on I-40 and I-81. Hope this helps.
Name:	Fridge fan 1.jpg
ID:	5594   Click image for larger version
Name:	Fridge fan 2.jpg
ID:	5595   Click image for larger version
Name:	Fridge fan 3.jpg
ID:	5596   Click image for larger version
Name:	Fridge fan alligator clips.jpg
ID:	5597   Click image for larger version
Name:	Fridge fan switch 1.jpg
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 05-08-2011, 01:29 PM   #2
janegraves's Avatar
Great post. I've ordered my fans, (along with other fun stuff) and will give it a try. I love that site. I've bought from them before. Long shipping time but great prices.
janegraves is offline   Reply With Quote
Old 05-08-2011, 01:36 PM   #3
MtnGuy's Avatar
Old 06-13-2011, 12:47 PM   #4
strlw's Avatar
Ordered my fans and recieved them. Going to install today. Great idea. Alot better than those battery operated fans for $15.00
strlw is offline   Reply With Quote
Old 06-18-2011, 08:19 PM   #5
vasnipe's Avatar
Good luck with the fans. I'm interested in any improvements or different ways to go about the thing.
Chris in Virginia
Old 06-18-2011, 10:39 PM   #6
Thank you. I will talk to DH and get ours ordered too. I already found a few other things I would like to get. That is a cool site.
Donna=Me Tom=DH
2 DD's-grown, 1 DS grown, 1 SIL
4 DGD's, 2 DGS, 1 Pekingese(7/1/1999-6/18/2016)
2011 Shamrock 23ss
2000 Suburban 1500 4 X 4
ngts camped 2016-24 so far. reservations for 11 more
ilovecamping is offline   Reply With Quote
Old 06-23-2011, 02:25 PM   #7
RubenZ's Avatar
I have a bunch of computer fans laying around here and probably going to make something similar. By any chance do you have more detail view of how you rigged the fan power? Are the Ground Connections the Alligator clips?
__________________________________
Ruben Zamora
2007 Silverado 2500HD 4x4 Dmax/Allison, 4" Exhaust-no cat-no muffler
2012 Palomino Puma 23FB
RubenZ is offline   Reply With Quote
Old 06-24-2011, 07:18 AM   #8
strlw's Avatar
Hook the ground wire to one of the alligator clips and the hot wire goes to the input side of the light switch inside the refridge. This will keep the fan running anytime the fridge is on and won't cut off when the light goes off.
Old 06-24-2011, 07:28 AM   #9
Fire Instructor's Avatar
Has anyone who has one of these calculated what it draws? I'm paranoid about adding any more parasite loads to my electrical system. Is there any kind of watts or amp rating on it?
Does anyone with a Xantrex, Rogue, or any other controller/monitor that monitors load realtime have one of these fans?
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 06-24-2011, 08:38 AM   #10
RubenZ's Avatar
The big FAN I have from a Server is 120mm and when I checked was 12V and 1.5A I thought that was kind of a lot so I may just find either a smaller 90mm fan or smaller. Not sure yet. This big fan is fast and draws and pushes a crap load of air. I looked at another fan here that seems to be either 60mm and it shows it would draw .70A so it varies. Bigger fans are slower but push more air. It's just a matter of finding the right fan.
For Example, THIS ONE is only .40A
And THIS ONE is bigger but draws only .35A and has a life span of around 50,000 hours.
You also want to look at db(decibels) to see how loud they run.
Ruben Zamora
fan
