Old 09-29-2012, 10:28 PM   #11
B47
Originally Posted by 2306Rick View Post
yup. this seems so cheap, in addition... how does sliding a plastic sleeve up/down one of the metal fins adjust the temp? has anybody figured that out?
while camping the past couple days adjustments up & down didn't change the temp anything too noticeable.
Herk or Turbo - perhaps one of you can jump in here and explain.
Old 09-30-2012, 08:49 AM   #12
2306Rick's Avatar
Originally Posted by VinceU View Post
Never saw it apart Rick, just slid it a few times, look inside the plastic for a indent area, if none I'd center it to get max adjust range.
Thanks for the pic's & input Vince.
2011 Ram 1500 Hemi Quad Cab 4x4
2011 Mini Lite 2306
2 kids
2 dogs
... oh yeah, the wife too.
2306Rick is offline   Reply With Quote
Old 09-30-2012, 10:36 AM   #13
VinceU's Avatar
Do you have this adjuster in your rig? These are becoming rare. Only used in smaller boxes and lots in older installations to adjust box temp, freezer was best case. Most now are 3 button choice or 0-5 choices on LED display.
Old 09-30-2012, 05:10 PM   #14
B47
Vince - yes we have this adjuster (it is called a thermsistor I believe) in our rig (2012 Silverback) in addition to the cold-coldest buttons.
There has been quite a bit of discussion about this recently. I suggest you do a search for more information - I might have not spelled thermsistor correctly.
