Old 04-07-2010, 03:12 PM   #1
Fuses for slide outs
Wildwood 312QBBS
Trying to disable slide switches to prevent accidental partial operation.
Removed all 12v fuses in panel and slides still operate. Any one know if
fuses are near motors for slides??
Underbelly is enclosed, so if so, I couldn't access them easily.
tkuchta is offline   Reply With Quote
Old 04-07-2010, 05:19 PM   #2
Knower of Some Things
The fuses for your slideouts don't look like fuses, some of the time. They are either manual or auto reset breakers, much of the time located up by your batteries (if you have a fifth wheel), or in the converter (little .25" x 1.25" tall block) in your fuse panel, as in the case of a Puma. There is a little reset button on that kind.
PumaPro is offline   Reply With Quote
Old 04-08-2010, 08:00 AM   #3
This is TT and see nothing near battery.
Will check again at panel. Sounds like this is not something that can simply be removed to disable slides for the duration of season. I leave TT in same site for entire season.
Thanks.
Old 04-21-2010, 04:50 PM   #4
My 09 has a fuse holder behind the slide switches. Why there I don't know.
railrode is offline   Reply With Quote
Old 04-21-2010, 09:25 PM   #5
j2detroit's Avatar
the breakers on my cherrokee are directly behind the batterys under the camper mounted on the insie of the frame rail you can only see them when on your back lookin up ps take a flash lite
j2detroit is offline   Reply With Quote
