Old 06-10-2014, 08:00 AM   #1
gate valve
Can a black tank gate valve go bad?
bparish is offline   Reply With Quote
Old 06-10-2014, 08:03 AM   #2
TURBS's Avatar
I guess in a matter of speaking "yes"
Seals.
Sticking.
Breakage.
What issues are you having?
TURBS
"Sabre owners united"
Old 06-10-2014, 08:06 AM   #3
onetonford's Avatar
They do eventually but they last for years. They sell repair kits for them also. I have had them fail from being used Dry rubber gasket rolls over. Also they have left things in tank when they cut the openings and get caught in the valve. also sawdust.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 06-10-2014, 08:08 AM   #4
If it is sticking or hard to open/close you could try this:TST Drain Valve Lube - 16 oz. - Camco 40246E - Sewer Cleaners - Camping World
Old 06-10-2014, 08:14 AM   #5
Seals.
Sticking.
Breakage.
TURBS
The gate valve works freely but nothing will drain out. The coach is level, and the valve is working. Could there be a blockage?
Old 06-10-2014, 08:19 AM   #6
onetonford's Avatar
Is it a cable pull remote?
2011 25 RL Wildcat
Old 06-11-2014, 11:51 AM   #7
Rich46's Avatar
Send a message via Yahoo to Rich46
Any valve can plug, open valve with a bucket under it & wash with a water hose to loosen up plug.
Or use a long rod, once fluid moves, close value drain tank & wash throughout the inside, after washing,
Inspect the inside of valve using a flashlight, repeat if needed. Determine what plugged the valve if possible.
One of the things is female napkins, ect. Hope this helps.
Rich46 is offline   Reply With Quote
