Old 03-27-2011, 07:30 PM   #1
Generator
I have a 2011 Rockwood Windjammer 3065. What size Honda generator would be the right size?
Boggs104 is offline   Reply With Quote
Old 03-27-2011, 07:45 PM   #2
sherdep's Avatar
what accessories do you plan on running with the generator
Fridge?
A/C?
Converter?
Microwave?
Here is a Formula for you to figure it out if no one steps in to help
Convert your total power use into watts. You may have some appliances that only provide power use in volts or amperes. Convert these to watts by multiplying the amperes by the volts. If you have a refrigerator that is 10 amps, you will multiply it by 120 -- since most U.S. households use 120-volt outlets -- for a total of 1,200 watts.
Add the wattage of all appliances you plan to operate continuously and buy an appropriately-sized generator. You may want to keep a list of the power requirements for all appliances handy so you can unplug some appliances and use others.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-27-2011, 08:54 PM   #3
Location: Canandaigua,New York (The heart of the Finger Lakes)
I have a 3065 also....I bought a Yamaha 4500/Inverter for mine. Runs everything great!(A/C-15,000 btu etc) Its real quiet..but also expensive/heavy-198lbs.,you'll neede a quiet one to run in the parks because the other campers will run you out of town with a $400 construction grade generator. If I had to do over I'd get 2-2000watt/inverter Yamaha's to run in tandum,that way if you dont need all the power to run the A/C you can run one only. Plus they are alot lighter to carry around (1-2000 watt. is around 48lbs)! Honda's are good too,just think Yamaha's are just as good and a little cheaper.
BigRed is offline   Reply With Quote
Old 03-27-2011, 09:03 PM   #4
So, I could get by with one 2000watt if I chose not to run the A/C?
Old 03-27-2011, 09:11 PM   #5
Yes , If your not using your A/C -- and use the method for adding up the wattage of what you want to use as Sherdep says. I dont see you having much of a problem as long as you dont need the A/C and dont run the Microwave every other second!!
Old 03-27-2011, 09:15 PM   #6
