Old 09-18-2016, 11:29 AM   #1
Generator Use Tips
First, thanks to all who chimed in with their advice on the choice of a generator. Based on your comments, I've chosen a Champion 3800-watt unit. I know it will not be whisper-quiet and light as a feather like inverter units from Japan, but it is a good compromise and most of you who've had them find them acceptable and a very good value.
Now, I have a few questions on their use...
The first question I have regards positioning your generator. I have a 30-ft TT30-to-110v cord, so I am limited to placing the gen 30-feet or closer to my trailer.
What I was planning on doing is to just leave the generator in the bed of my pickup. This thing weighs 120lbs so I hate to unload from the truck and load it if I do not have to. However, the owner's manual specifically advises against running it from a pickup bed. So where else might I locate it so its noise is minimized and it is level and stable?
The second bit of advice I am looking for regards grounding of the generator. The machine has a grounding lug on its control panel and the manual says I can just ground it to the frame with a 12-gauge or heavier strap . No ground strap is provided, though, so I'm wondering what others use. It also says you can ground it to a copper ground stake that is driven into the soil. That sounds like more than a little bit of a hassle.
What do you all do to ground your generator when camping?
Thanks for your help.
mrgem is offline   Reply With Quote
Old 09-18-2016, 11:36 AM   #2
Most C/G sites are NOT 30' wide,so your Neighbors will be Impacted with Your Noise! Now if you are Boondocking just Buy a Ex cord that will place the Genny as Far away as makes You comfy! Youroo!!
Old 09-18-2016, 11:48 AM   #3
northstar1960's Avatar
Leaving it in the bed of the truck is fine . if you have no topper even better . no real need to ground unit . you can but not necessary. I use a copper rod into the ground then a clamp but have found it was overkill .
lots of campgrounds have hours where generators can be run and yours is not as loud as a lot of diesel boilers in lots of motor coaches and doesn't smell as bad . and not everyone goes to campgrounds to camp
northstar1960 is online now   Reply With Quote
Old 09-18-2016, 11:53 AM   #4
NMWildcat's Avatar
Good luck with your new generator and also with your neighbors giving you the evil eye Lots of threads/articles concerning grounding. I've never actually seen anybody ground their portables.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-18-2016, 12:22 PM   #5
another_newfie's Avatar
Leaving it in the bed of the truck is fine. I've done the same for years.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 09-18-2016, 02:46 PM   #6
Moderators' Assistant
bikendan's Avatar
I'm sorry but most of us that own the Champion 3800 would NEVER use it in a campground.
Yes it's a great value but it isn't appropriate for campground usage.
I use mine for backup power for the house.
Not sure where you got the idea most approve of it for campgrounds. :what:
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 09-19-2016, 09:45 AM   #7
to be a good campground neighbor then you use no generator cause your honda is very annoying to many as is any generator use . but if your going to use them then all need to be accepted . some love to think their stuff don't stink . but nothing worse then camping out where there are few other campers and the guy with his honda thinks he can run it all night just because it's not a rv park .
Old 09-19-2016, 10:01 AM   #8
most parks only allow inverter type generators. Champion makes open frame and the inverter type.
you probably wont make friends by using an open frame, it will significantly louder.
I run my generator in my truck bed under the camper shell when it rains. It works fine
2015 Ram 2500 4x4 6.4l with 2015 Flagstaff 21FBRS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 09-19-2016, 10:06 AM   #9
Where did the OP say they were going to use this generator in a campground?
I agree it would NOT be acceptable but I also didn't see where using it in a campground was mentioned. Maybe the plans are to use it boondocking somewhere alone?
To the OP... I see no reason you couldn't leave the genny in the back of the truck.
I've done it MANY times.
If you have a topper, open the windows and leave the t/gate open.
If no topper, just fire it up.
There is no harm in using a 30 amp extension cord either.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-19-2016, 10:15 AM   #10
Just a little off topic, but all those who are running a genny in the back of a pickup are you a least putting some sort of vibration damping ( as in rubber mat) under the gen to absorb some of the vibration/noise from the frame of the unit sitting on the bed of the truck?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is online now   Reply With Quote
generator
