10-06-2018, 10:09 AM
Charles E
Georgetown Power Cord Rat Seal
What is the best remedy for blocking rats or mice from climbing up the power cord and getting into the coach?
10-06-2018, 10:37 AM
Kanadian Kamper
So far, I’ve stuffed....and I mean stuffed, the remaining opening with giant sponge foam to fill the gap. If I find it doesn’t work, I’ll stuff it with steel wool....apparently that works pretty well to keep critters away.
Ken and Terry
10-07-2018, 07:12 PM
Our power cord connects to the outside but I was concerned about the same issue with the opening / pass through for the water hose.
I had a 8x8 piece of corian laying around. I put a 2 1/4 hole in it and place it over the opening with the hose going through it. I then take a piece of pool noodle over hose and shove it into the 2 1/4 hole. It's a pretty tight fit and does the job!
Jim
2018 Chevy 3500 Crew Cab, 4WD Duramax
2019 Cedar Creek Silverback 33ik
10-07-2018, 07:27 PM
I don't know how practical this would be but we put rat guards on the mooring lines of our ships when I was in the navy.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Only one shedding mutt now RIP Yoshi
10-07-2018, 07:37 PM
I'm not familiar with the area your talking about ~ so I can only suggest 2 ways to prevent entry:
#1 - try to attach 1/4" hardware screen. Cut a square piece large enough to cover the hole, cut toward the center from one side and then cut a small hole in the center for the cord to pass thru. Attach to your unit by screws with washers to hold the screen in place. If possible, spray foam over the screen.
#2 - stuff the hole with coarse grade steel wool. Separate the wool somewhat and stuff the area of concern. Spray foam over the steel wool will help hold in place.
Using foam alone will not stop them as they can & will chew thru the foam.
Good luck ~~
10-08-2018, 12:40 PM
We use stainless steel pot scrubbers.
For the winter we have loaded up with peppermint oil on cotton balls and some of the cab rid packets.
Here’s hoping!
10-08-2018, 12:43 PM
http://www.forestriverforums.com/for...-78734-14.html
I'm not familiar with the Georgetown, but this is what I did to my FR3. I used a hacksaw and a round file to carve out a slot in the plastic cap. The cord goes through the hole... then I put the cap on and position the cord into the slot..
The cap still treads on and there isn't enough room for anything to fit up the power cord and into the coach.
2015 FR3 30 DS
1995 Wrangler
Miles 9100
Days Camped 74
10-08-2018, 01:05 PM
New:
X2
2017 Days Camping = 5 soon to be 12!
2016 Days Camping = 38
2015 Days Camping = 48
New: 2015 Forest River Georgetown 328TS
2016 Equinox Tow Vehicle
old: 2013 FR Rockwood 2318G w/ 2001 Ford F250 4X4 Diesel
10-08-2018, 06:16 PM
Great answer 2jump36...shoulda thought of that myself. Evidently the FR3 and current G’towns have that configuration in common! Will be giving it a try for sure.
2019 Georgetown XL 369
2017 Ford Fiesta Hatchback toad
10-09-2018, 02:56 PM
10-09-2018, 03:03 PM
Originally Posted by zipmart
Here is my solution. I cut a four inch circle out of some scrap 1/2" MDF and a five inch circle out of some 1/8" fiberboard. I drilled a half inch hole in each piece and a 1/4" hole in each center. I cut an angled slot in each piece to the 1/2" hole and joined the two with a 1/4" bolt and nuts with the slots facing opposite directions. Rotate the pieces so the lots open up in a common opening and then rotate the pieces so the slots close around the cord and insert into the floor opening.
Now this is an invention!
10-10-2018, 06:53 PM
Patent it quick! Love it!
2018 Georgetown 378 XL
Loved her, listed her, sold her
