Old 04-10-2016, 06:56 PM   #21
mrpep's Avatar
mrpep is offline   Reply With Quote
Old 04-10-2016, 07:10 PM   #22
caper's Avatar
https://youtu.be/rfJHEHlTsXI
Try opening the link. It is a video on how to light your water heater.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-10-2016, 07:13 PM   #23
crunchman12001's Avatar
Spiders and stink bugs crawl into the opening in that gold colored tube. Make sure to blow that out.
2015 F-250 FX4
Old 04-10-2016, 07:15 PM   #24
mrpep's Avatar
Excellent video, that is my exact units. I actually followed those exact steps though and no luck. How do I know if there is water in the tank? I had water running out of all of my interior faucets and toilet so I assume the tank has water too, right ?? If not, how do I load it and could this be why I can't make it work ??
Old 04-10-2016, 07:16 PM   #25
bikendan's Avatar
Originally Posted by mrpep View Post
What is the gray and black? I'm new, just bought this and have not taken it out yet so am cleaning and getting things in order .
Are you asking what gray and black mean or what are the capacities of the gray and black?:what:
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-10-2016, 07:16 PM   #26
mrpep's Avatar
I did blow out but ..... I didn't blow inside that tube , ok, gotta try this again
Old 04-10-2016, 07:44 PM   #27
mrpep's Avatar
Pilot is on!!!!! Now, why is the entire flame not on ? It's only pilot ? Getting closer !
Old 04-10-2016, 07:54 PM   #28
To assure water is the HW tank, open the pressure relief valve on the tank. Water will come out of the valve when full. Also, in an older unit, you probably have an anode rod on the tank drain plug which I assume will need replaced too.
2015 F-250 FX4
Old 04-10-2016, 07:55 PM   #29
mrpep's Avatar
Getting my old tt ready but then.....
Is the anode a 1-1/16" socket which I don't have . Is that a standard size ?
Ok, checked again and tank appears to be full of water cause pressure valve is pouring out water . Still no large flames though on burner .
Old 04-10-2016, 08:08 PM   #30
You have to track it down from the tanks to the burners. If you have propane in tanks (you said stove works) then track the line all the way to where flame is in water heater. You say pilot is on... well check the orifice at burner tube for blockage. Go to home depot, buy the correct socket and check to see if anode rod is bad, that will be next when you get flame at burner tube.
2015 F-250 FX4
