Old 04-11-2016, 01:37 PM   #51
rmac04401's Avatar
Name:	ImageUploadedByForest River Forums1460399698.509854.jpg
My old Fleetwood. I had the white switch in front of sink that needed to be on for WH to work. Although I was always able to light piglet no matter whether switch was on or not. But needed switch on to get hot water.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-11-2016, 01:38 PM   #52
mrpep's Avatar
I'm at home and testing and repairing , I bought an oldie that was collecting dust for a few years. So far so good it's in decent shape. I just have a little TLC to do here. I'll upload pics.
mrpep is offline   Reply With Quote
Old 04-11-2016, 01:41 PM   #53
mrpep's Avatar
Old 04-11-2016, 01:49 PM   #54
mrpep's Avatar
So far the toilet has a leak and the part was 25$ , the water heater won't start correctly, yet and a seal under the kitchen sink seems to leak but I think a tighten will take care of that. All that sitting around may have dried and shrunk the seals is my guess. The AC, heat and faucets , showers , toilets seem ok - I think I can get this oldie to perform eventually and I don't think it will be too expensive, crossing my fingers. No leaks on roof, floors are solid and no mold , this is what matters the most to me.
Old 04-11-2016, 01:59 PM   #55
rmac04401's Avatar
It looks good. Has same floor plan my old Fleetwood had. If leak around sink drain you could always take it out and use new plumbers putty on drain. Maybe plastic ring in the culling is broken. Even if your water heater is bad if you got the trailer at good price a new water heater in less than $300. And you will still be ahead of the game.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 04-11-2016, 02:13 PM   #56
mrpep's Avatar
I paid 2500$ for it , not great but not bad either considering pop ups with no Ac and bathroom go for that much around here. I really like it ...
Old 04-11-2016, 02:18 PM   #57
rmac04401's Avatar
That's a good price. I used to say when I had my old one that I had just as much fun with my oldie but goodie as the ones that had the new ones.
Of course then I bought a motorcycle and had to upgrade to a toy hauler. We enjoyed the heck out of our old used camper. By the time your done you will know every square inch of it.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 04-11-2016, 02:24 PM   #58
rmac04401's Avatar
How's your awning? I replaced the one on my old trailer a year before I sold it. I had to replace the whole mechanism due to storm snapping it in two. Was pretty easy to install.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 04-11-2016, 02:26 PM   #59
mrpep's Avatar
Oh, I forgot to mention that I could not take down the awning , I have to figure that out next. In case I do replace I think I will go with manual. I think it's cheaper , right?
Old 04-11-2016, 02:43 PM   #60
rmac04401's Avatar
Getting my old tt ready but then.....
Yes much so. Plus you would have to go in the side to get power to it and fun wires. It would be a task.
You should have a long metal rod that has an L on the end. On the right hand side of the awening roller their is a little flip toggle switch. It should say on the toggle which way to flip it for Dow and which for up. You would dip it to the down selection. Then ther should be two black clasp half way between on the uprights. Squeeze the sides of the black edges and this will unlock the uprights. Then there is a strap with a loop on the end that you put that L piece into an start pulling to you until fully extended. Then you have adjustments on both sides to raise and adjust it so you don't catch with your door. Then you do it just opposite to put it back up. Just make sure before you flick the toggle to up you have ahold of the strap or the thing is going to go flying.
I'm sure if you go to Domatic website they have how to videos.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
