04-10-2016, 06:56 PM
#21
04-10-2016, 07:10 PM
#22
https://youtu.be/rfJHEHlTsXI
Try opening the link. It is a video on how to light your water heater.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
04-10-2016, 07:13 PM
#23
Spiders and stink bugs crawl into the opening in that gold colored tube. Make sure to blow that out.
2015 F-250 FX4
04-10-2016, 07:15 PM
#24
Excellent video, that is my exact units. I actually followed those exact steps though and no luck. How do I know if there is water in the tank? I had water running out of all of my interior faucets and toilet so I assume the tank has water too, right ?? If not, how do I load it and could this be why I can't make it work ??
04-10-2016, 07:16 PM
#25
Originally Posted by mrpep
What is the gray and black? I'm new, just bought this and have not taken it out yet so am cleaning and getting things in order .
Are you asking what gray and black mean or what are the capacities of the gray and black?:what:
#26
I did blow out but ..... I didn't blow inside that tube , ok, gotta try this again
04-10-2016, 07:44 PM
#27
Pilot is on!!!!! Now, why is the entire flame not on ? It's only pilot ? Getting closer !
04-10-2016, 07:54 PM
#28
To assure water is the HW tank, open the pressure relief valve on the tank. Water will come out of the valve when full. Also, in an older unit, you probably have an anode rod on the tank drain plug which I assume will need replaced too.
2015 F-250 FX4
04-10-2016, 07:55 PM
#29
Getting my old tt ready but then.....
Is the anode a 1-1/16" socket which I don't have . Is that a standard size ?
Ok, checked again and tank appears to be full of water cause pressure valve is pouring out water . Still no large flames though on burner .
04-10-2016, 08:08 PM
#30
You have to track it down from the tanks to the burners. If you have propane in tanks (you said stove works) then track the line all the way to where flame is in water heater. You say pilot is on... well check the orifice at burner tube for blockage. Go to home depot, buy the correct socket and check to see if anode rod is bad, that will be next when you get flame at burner tube.
2015 F-250 FX4
04-10-2016, 08:09 PM
#31
Is it 1-1/16 socket?
04-10-2016, 08:14 PM
#32
Isn't It just a plug since there's no terminals on it ?
04-10-2016, 08:31 PM
#33
It looks like most plugs are 1 1/16", I use a cresant wrench on mine.
Yes the anode rod is attached to the plug, it coorodes to protect the water heater. Pull the plug, flush the tank and replace anode rod if needed.
2015 F-250 FX4
04-10-2016, 08:33 PM
#34
The anode rod wouldn't affect the lack of flame though, correct ??
04-10-2016, 08:38 PM
#35
Turn the knob from pilot to on.
Terry and Janet
2007 Ford F150
04-10-2016, 08:45 PM
#36
I did but still no large flames . So I took off the nodes and here is what it looks like....
04-10-2016, 08:47 PM
#37
Since I'm now getting the pilot on and I'm turning to on and the pilot remains, could it be thermocouple ?
04-10-2016, 09:25 PM
#38
That anode looks bad, better replace it. A bad thermocouple would keep the pilot from staying lit. Did you try changing the thermostat setting to HIGH. From you picture it shows in the LOW position, try moving it to HIGH to see if the flame comes on.
2015 GMC Denali 3500 4X4 Duramax
2019 Cedar Creek 36CK2 (sold 4/21)
04-10-2016, 09:26 PM
#39
A bit late today but will
Definitely try tommorrow, hope I can get it
04-10-2016, 11:01 PM
#40
Yes, what are these black and gray ?
