Old 04-09-2016, 10:11 PM   #1
mrpep's Avatar
Getting my old tt ready but then.....
I have a 1998 forest river wildwood 24fb and today I finally got around to messing with it a bit more. So far so good but I do have some issues. For starters it seems like the floor vent in the bathroom kicks up more hot air flow than the other 2 floor vents , what would cause this? Then, all water flow seems to work except for the kitchen sink, it trickles , is there a valve or something that I have to turn ? I'm finding a lot of mouse droppings. I guess I can vacuum and the wipe and disinfect but what about in the floor vents?? How do I get in those ?? Now I also feel a hot air flow pouring outside through a vent through the wall, why is that happening?? I cause I could really use that hot air inside since I have the heat on. I have a couple of ceiling lights not getting voltage and that's about it and all fuses are good . Oh, I have a leak located at the top of the toilet in the rear where the hose plugs in but I'll open a separate three for that . So please , what ever pointers you can give here, I will appreciate, thanks.
mrpep is offline   Reply With Quote
Old 04-09-2016, 10:41 PM   #2
rmac04401's Avatar
Take off your aerator on your sink and check for dirt. This restricts flow. As far as heat is the vent giving you the most heat the first one in the run/trunk? My suggestion would be take resisters off and stick shop vac hose down to see if you have mouse nest built in the trunks since you have said you see signs.
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 04-09-2016, 10:48 PM   #3
mrpep's Avatar
Eh, kinda grossed out by all this but no pain no gain. I'm gonna do some hard core vacuuming and wipe downs with bleach and then shampooing all seats . I actually found that the screen was blocked with dirt, I cleaned and that helped . I did find a leak at the top of the faucet , I'm gonna replace , I don't wanna take any chances. Can I use a regular kitchen sink faucet ??
Old 04-09-2016, 10:53 PM   #4
caper's Avatar
The heat vent on the outside is the exhaust vent for the furnace. The floor vents have a screw on each end. Remove the screws and the vent lift off. X2 on removing the aerator and checking for blockage. If this does not work you might have to replace the faucet. You can replace the faucet with any regular kitchen faucet.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-10-2016, 10:02 AM   #5
mrpep's Avatar
Ok so I'm in here and boy is it fun vacuuming up nice **** ???? Yeah right, anyway, I am trying to turn on hot water heater but when I press the pilot down and hold it no gas comes out. What am I doing wrong ?
Old 04-10-2016, 10:10 AM   #6
rmac04401's Avatar
Sometimes it takes a bit for the piglet to light. You sure tanks are on right?
2016 Grey Wolf 26rr
2005 Honda VTX 1300
Old 04-10-2016, 10:11 AM   #7
Georgia Frog Rally 2018
aceinspp's Avatar
Are your propane tanks full and have you turned them on? Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 04-10-2016, 10:14 AM   #8
SeaDog's Avatar
Check that the pilot tube is not blocked with dirt or spider webs. You may have to hold down the pilot knob so much longer then what you think at least the first time to purge air and such. Check your main tanks and ensure they are full
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-10-2016, 10:17 AM   #9
mrpep's Avatar
Tanks are full , I'm running heated air and ok, I will blow out that whole area and hold down longer , thanks and I'll be back in a few minutes .
Old 04-10-2016, 10:23 AM   #10
aceinspp's Avatar
Being you had other criders in your camper may have had mud dubbers make nest in pilot tube or gas orifice is plugged. Later RJD
Days camped 2017 62
Days camped 2018 18
