08-08-2012, 06:41 PM
#41
Can downy be used instead of Calgon? It was recommended by one of the workers at the RV dealer.
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6) Days camped in 2015-18, 0 Days so far
Days camped in 2019, (8)
This Space for Rent
08-08-2012, 07:29 PM
#42
NO NO NO!!
THe worker was "thinking" of Calgon but said Downey instead. NOT the same stuff. Downey or any other fabric softener is a liquified wax. It coats stuff - and if you have a front loading washer you probably know (or should know) that the scummy waxy residue that liquid fabric softeners leave behind is the place where mold finds a happy home and makes front loaders stink!
You are trying to make your black water tank cleaner - helping gravity to drain away more of the nasty stuff in the tank, not create a new hazard for additional stink!
As a side note - don't use liquid detergents that contain fabric softener for the same reason.
***** ***** ***** 2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
08-08-2012, 07:48 PM
#43
Originally Posted by 2Susan
NO NO NO!!
Good tip Susan. Ditto on the NO! NO! NO!
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
08-08-2012, 11:30 PM
#44
08-09-2012, 03:43 AM
#45
Originally Posted by Rebel702
Thanks already found it there but love that you did as well.... Prime shipping as well
Time spent 2012 in TT 32 days so far and 21 Planned days this Fall with mini trips in between
2009 Chevy Silverado 1500
2012 XLR Hyper Lite 27HFS
1999 Yamaha Grizzly
1996 HD Dyna Wide Glide
08-09-2012, 09:41 AM
#46
Thx for the Amazon tip... previously I have only located the liquid at my local W-mart.
Does anyone know if it make any difference whether to use powder vs. liquid? Price is similar.
2012 Ford F150 4x4, 5.0L, 3.55 2011 Rockwood MiniLite 1809s E2 WDH 600/6000lbs
08-15-2012, 09:25 PM
#47
Will be using this treatment from now on, it only makes sense to help in the coating of the black tank!
08-15-2012, 09:39 PM
#48
I prefer the liquid. It is easier to measure and it all gets into the tank.
08-15-2012, 10:30 PM
#49
Welcome to the forum!
02-15-2013, 09:03 PM
#50
Is it the same amount if you use liquid instead of powder? I mean the 1 cup measurement for each.
02-15-2013, 10:30 PM
#51
Not sure ! hmmmmm someone surely knows !
02-16-2013, 07:59 AM
#52
Doing the laundry is not part of my normal duties, but I fill in in a "pinch."
Does not the powdered bleach have soap in it?
I use PURE UNSCENTED LIQUID Chlorox because all I want in that water is chlorine. Buy a small bottle just for this if nessessary an you will get two applications.
02-19-2013, 09:08 PM
#53
Ok I sort of scanned the posts in here and there are several errors putting calgon and laundry detergent is not the geo method. Also an fyi for anyone that wants to use the geo method go to the link someone posted earlier. The powdered calgon for some reason doesn't work as well as the liquid while using the geo method. Also some campground owners don't like you to use bleach in your holding tanks because it kills the bacteria in their sewage lagoons. With that said I have used the geo method and it does work. I also when using the regular chemicals in my tank occasionally run a batch of the geo method through to clean my tank. I also use it at the end of the season.
I put the stuff for the geo method in the tank after I dump it. Then agitate the contents with my wand or tank flusher. I fill the tank to the top then drain then fill it again and rinse.
I am a seasonal camper and since my camper doesn't move so I need to do it this way to keep my tank from getting nasty. If I traveled on the road I would do this while traveling so the tank gets agitated real well then hit the dump station when you reach your destination.
There was a lot of discussion on another RV web site and the geo method has been researched to death. Another thing if you guys are using Rv toilet tissue you could be wasting money. They also did studies on how t.p. dissolves and they found that Scott's tissue dissolved almost as well as R.V. tissue. Also it allows you to finish wiping before it dissolves.
02-19-2013, 10:06 PM
#54
I have used Scott for years, at home and in the camper. It works fine with no poblems.
02-20-2013, 08:01 AM
#55
While NOT the actual Geo-Method, the Liquid Calgon/Liquid Detergent treatment works for me since we never keep the crud in the tanks any longer than neccessary. Making the liquid slippery enough to completely evacuate the tanks (dumping into the "Blue Boy" or at a dump station) using gravity alone is the goal. When the flush is available we always do a 30 minute turbo-flush.
Here is the "actual" Geo-Method procedure.
02-20-2013, 01:06 PM
#56
Originally Posted by Wiscampsin
Fantastic. Thanks !
2013 Fleetwood Discovery 40G
BlueOx Aventa & Patriot Braking System
2009 Jeep Wrangler Unlimited
02-20-2013, 01:32 PM
#57
I also use the GEO method. I use both the liquid and the powder, depending on what I can find. With the liquid I pour in a couple of caps full. With the powder it's 2 cups, into a gallon pail of hot water. A cup of liquid clothes detergent goes in also.
02-20-2013, 03:33 PM
#58
I wonder if my system is much different. I use two of those little "packets" of dish washer detergent each dump. Just throw them in with two big flushes of the toilet and go. the motion during travel mixes them up.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
02-20-2013, 07:31 PM
#59
Do you mean something like this stuff?
http://www.cascadeclean.com/us/cascade/product
02-20-2013, 08:43 PM
#60
yes, thats the ones.
