Old 10-19-2013, 11:04 PM   #1
Great way to secure plexiglas to a screen door
I searched for a long time to find a good way to keep plexiglas secure in a screen door without having to drill holes. A clear plastic offset mirror clip ( made by a company called Anchor) will slide perfectly into the indented part of screen surround. The offset part ( part with the screw hole) holds the plexiglas against the inside part of the screen door.
You need to buy two packages. They come with an extra small piece that you don't need. The upper part of the door requires 5 clips. One in the top center and two on either side. The bottom piece requires 5 also but needs the clip on the bottom instead of the top. The middle piece which is about a foot wide needs two clips on the left side of the door with the other end cut long enough to fit behind the middle brace. The middle piece by the door handle fits into the sliding track.
I've gotten lots of compliments on this system and most people think I bought the plexiglas and clips as a kit. I got the plexiglas at Lowes who also cut it to my dimensions. Used a coping handsaw to cut the top corners. I hope this helps someone.
Murphie is offline   Reply With Quote
Old 10-20-2013, 03:43 AM   #2
cpaulsen's Avatar
Sounds good!! I just used velcro on mine and used my Dremal to cut and round the corners.
cpaulsen is offline   Reply With Quote
Old 10-23-2013, 01:43 PM   #3
Murphie
If possible could you post some pics
___________________________________
Salmon Hunter
2011 Crusader 320 RLT/ Honda 3000ei
2006 Chevy 2500HD 4x4 Crew Cab/Duramax Diesel/Allison Transmission
Salmon Hunter is offline   Reply With Quote
Old 10-23-2013, 01:59 PM   #4
Resident Masshole
force's Avatar
(I've always wanted to post that)
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
door
