Old 09-22-2014, 04:19 PM   #1
Iwannacamp's Avatar
Grey tank smell??
I have noticed a "black tank" type smell after I haul my trailer somewhere. It's pretty bad and lasts a day or two after we park. I have flushed the shower(we don't use) and bath sink. We hardly ever use the vent fan and haven't flushed anything yet. The smell is pretty bad.
Should I try to flush/sanitize the gray tanks? If so, then a suggestion on that would be helpful. I have read some about this and don't see a "fit" for my problem. The system is stock as far as I know. The smell doesn't seem to be about the sink or under.
At this point I am interested in any ideas.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 09-23-2014, 01:12 PM   #2
Fulltime family RVer
Exact same thing here. We do have a smell in our main bathroom from our shower after towing the camper for any "decent" distance.
Wife bought some gray tank deodorizers and we drop one into the sink (shared with the shower). You run water and it immediately dissolves. Bought it from Walmart.
ependydad is online now   Reply With Quote
Old 09-23-2014, 01:23 PM   #3
Iwannacamp's Avatar
Cool. Thanks. I will get some.
2017 Puma 297RLSS
Old 09-23-2014, 01:26 PM   #4
You need to keep the drain P traps filled with water. Sometimes, when you empty the grey tanks, the suction will pull the water out of the traps.
Old 09-24-2014, 12:24 AM   #5
Exiled Bohemians's Avatar
I love how much this forum hope me overcome the novice learning curve - I didn't know about keeping water in the traps...
Traveling 9/1/2014 - 11/1/2014
2015 Vibe 6504 ē 2005 BMW X5
http://instagram.com/bohemians_in_exile
Exiled Bohemians is offline   Reply With Quote
Old 09-24-2014, 09:23 AM   #6
Interesting note about dumping the gray pulling the water out. I didn't know it would do that, but it does make sense.
But, I rarely dump immediately before leaving any more. I usually do it the night before. The next day I'll get a shower before we hit the road (sometimes even after I've disconnected everything).
Old 09-24-2014, 09:29 AM   #7
also if the trailer sits for a while between uses, the water in the traps can evaporate and allow odor to come thru. dump some Pinesol, Lestoil or similar thicker-than-water in the traps and it will stay a lot longer.
steveh326 is offline   Reply With Quote
Old 09-24-2014, 10:11 AM   #8
Shower (Traps) in a RV are Not as deep as others. They can (Drain/Evap) easy! Youroo!!
Old 09-24-2014, 11:19 AM   #9
And apparently the traps in Sabres are some new fangled trap that isn't a "P". It is straight through but has some nodules on the inside that act as traps.
This looks like it is it:
http://www.drainmaster.com/main/2011...to-the-rescue/
Old 09-24-2014, 11:25 AM   #10
Boss Ox & Drovergirl
oxcamper's Avatar
I always run water down each drain aftere dumping to make sure there's water in there.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
tank
