Old 04-19-2015, 02:23 PM   #1
ColoradoRick's Avatar
Handy Gadget: Non-Contact Laser Temperature Gun
While a laser temperature gun may run over $20 at hardware stores, they're closer to $10 on Amazon.
I love mine...I use it to check the level of propane in my tanks. (You just start near the top and slowly go down while watching the temperature...as soon as the temp drops a few degrees, that's the level.) Tip: Let the tank go empty and, with a permanent marker, mark the spot near the bottom with a line and an E. Then, go get it filled and mark the FULL line near the top. No more guessing on how full a propane tank is. (You could, also, pour warm water on the tank before doing this to get a more definitive temp change.)
You can, also, use the gun to search around windows and doors to find any spots that aren't sealed and can also use it to check the temperature of air coming out of registers. (Just about anything, actually, as long as you can get within about a foot of it.)
This summer, I will also use it to check the temperature of my tires and brakes while driving. (Brakes can get very hot coming down our mountain passes here.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 04-19-2015, 05:46 PM   #2
Todouble's Avatar
Yes there great but for 10 bucks I can't imagine it's too accurate or will hold up to well. I use mine all the time for various things.
Todouble is offline   Reply With Quote
