Originally Posted by itat
That's not universally true. With the Equal-i-izer system, the bars don't have to be removed for backing up. The only time I can think of that you'd be advised to remove the bars is when you're backing up an incline to park your trailer. If the trailer is on the incline and your tow vehicle is on the flat, it may be impossible to get the bars off in that situation. Otherwise, there's no need to remove the bars, unless the noise is really bothering you.
The above only relates to the Equal-i-izer WDH. I have no experience with the chain type WDH.
I also find that if the camper and trailer are not straight it can be a pain to remove the stabilization bars. I recently had that happen to me, truck and camper were level but the truck was at an angle as the site was little small to have both the truck and camper straight. Was a pain to remove the bar on the "loaded" side. In the future I am going to remove the bars while the DW is checking in at the office. No real need to have them when moving around in the campground since speed is slow.
