Old 10-06-2015, 04:10 AM   #1
Help! Horrible noise!
We have been on 6 outings with our Heritage Glen 30' TT and love it. First time campers. We've had some glitches and a bunch of "learning experiences" but here is a new one. Everything was great when we parked on Thursday but when we left on Sunday we had this horrible groaning sound coming from underneath the trailer and couldn't figure out where it was coming from. Think it might be the brakes?
Everything was closed up correctly and the only thing that happened from when we parked to when we left was that we had the right side up on blocks to level and it rained like crazy 2 of the 3 days. Can anyone tell me what we should check first before our first road trip coming up this weekend?
Debbie
xtranicedeb is offline   Reply With Quote
Old 10-06-2015, 04:26 AM   #2
Alleged curmudgeon
Vern's Avatar
While it is not possible to say for certain what the noise would have been with the limited description here, such a question commonly often leads to the conclusion that the new TT owners were surprised at the popping and groaning of their weight distribution hitch (WDH). Our Equalizer hitch makes a lot of noise at arrival and departure (i.e., when turning sharply), and that is normal. Could that have been what you heard?
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30)]
Vern is offline   Reply With Quote
Old 10-06-2015, 04:45 AM   #3
EastlakeRoo's Avatar
I agree, weight distribution hitchs do make a lot of noise. I would keep and eye on things and see if this is what you hear. Sometimes the trailers themselves will make some noise as well. All normal.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 10-06-2015, 05:20 AM   #4
OK I'm so stupid ... is the weight distribution hitch the same as the trailer hitch? Why would it suddenly make noise if it's never done it before?
Debbie
Old 10-06-2015, 05:49 AM   #5
RSchleder's Avatar
Did it occur as you were turning out of your campsite onto a campground road? Yes, the WDH is the trailer hitch with weight distribution bars. These systems do creak and groan, especially when turning a sharp corner!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 10-06-2015, 05:52 AM   #6
nomad297's Avatar
Problem solved!
Bruce
Old 10-06-2015, 06:29 AM   #7
B and B's Avatar
You mentioned rain.... Rust metal on metal contact. What kind of hitch? If something is suppose to have grease maybe it needs some otherwise you just have to live it on friction surfaces.
Old 10-06-2015, 11:41 AM   #8
Weight Distribution Hitches
Your weight distribution hitch bars and sway controls should be released prior to spotting or backing a trailer. Makes it much easier on you and your rig. Especially when stretched tight enough to make it ride smooth. Also depends on whether it's raining or not...
Izzymovin is offline   Reply With Quote
Old 10-06-2015, 11:55 AM   #9
Canadian Member
That's not universally true. With the Equal-i-izer system, the bars don't have to be removed for backing up. The only time I can think of that you'd be advised to remove the bars is when you're backing up an incline to park your trailer. If the trailer is on the incline and your tow vehicle is on the flat, it may be impossible to get the bars off in that situation. Otherwise, there's no need to remove the bars, unless the noise is really bothering you.
The above only relates to the Equal-i-izer WDH. I have no experience with the chain type WDH.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
itat is online now   Reply With Quote
Old 10-06-2015, 12:25 PM   #10
Boso's Avatar
Noise
If it is a equalizer hitch the more noise the better it is working that means more friction don't worry about rust it cleans itself
Boso is offline   Reply With Quote
Old 10-06-2015, 01:38 PM   #11
Rick_Geneseo's Avatar
I usually left mine on when backing on flat ground. As far as noise, i cired most of mine when i WD40 all the chains and used marine lithium grease on the trunion bars.
Rick_Geneseo is offline   Reply With Quote
Old 10-06-2015, 02:43 PM   #12
If you have a sway control device that hooks to the trailer tongue and your hitch head, those can suddenly make noise, especially if they get rusty.
frisbyh is offline   Reply With Quote
Old 10-06-2015, 03:46 PM   #13
Pixelbum1's Avatar
Yep, yup. I agree with you and also B&B prior re the rust. I was always
advised to not grease the contact points on the WDH as you WANT a little friction and resistance to help it "do it's thing". THAT being said tho...it probably wouldn't be a bad idea to lightly grease those points (same grease you use on the hitch ball) just to see if the problem rights itself which I think it will.It rained for two days...TT was on a tilt during that time...which unwittingly exposed one side of the WDH more to the weather and guess what...then you got the rust. However, it should go away by itself the more you drive it, sooner or later... If not then take it to the dealer and perhaps start with the bearings in the wheels? Break a leg!
PS: I never removed my WDH, or any of that when backing into a site with my former 25' TT with dual axles. I think it actually made the backing process much MORE predictable and accurate, spotted or not, so nah!
Si Hoc Legere Scis, Nimium Eruditionis Habes!
Pixelbum1 is offline   Reply With Quote
Old 10-06-2015, 03:58 PM   #14
RSchleder's Avatar
I'm wondering if any of these replies have any relevance to the poster? How about a little feedback to let us know if these replies are of any help to you? Do any of the circumstances we described "mirror" the situation you experienced?
30 years RV'ing
11 different RV's
Old 10-06-2015, 08:47 PM   #15
Sounds to me like the "sway bar" they do that when they are wet.
harpplayer is offline   Reply With Quote
Old 10-06-2015, 09:06 PM   #16
We recently had that happen to us. I lube the spring bars and ball, do they run smooth. They creak a little and the chains pop a bit making turns. Last week, the back of the Tahoe started moaning like two newlyweds on their honeymoon! It freaked out the cats (one of whom is the quintessential hairy chicken )! I traced the noise to the anti-sway control bar. I cleaned the bar and it helped. I think I need to adjust the bolt on the other side to square up the brake that dampens the sway. Anyone have any other ideas?
2015 Palomino SolAire 20RBS
2017 1500 Silverado LTZ Z71 with 6.2L, 8-speed & tow package
2015: 18 days; 2016: 21 days; 2017: 19 days; 2018: 26 days; 2019: 8 days (so far)
elchilero53 is offline   Reply With Quote
Old 10-06-2015, 09:11 PM   #17
Carknocker Family
Ida Ratherbe Camping's Avatar
My first thought was that they forgot to unhook breakaway switch when setting up, pulled cable out then drug it home with brakes set. But reading replies, I can agree on WDH also.
Ida Ratherbe Camping is offline   Reply With Quote
Old 10-06-2015, 09:14 PM   #18
B and B's Avatar
X2
Old 10-06-2015, 09:51 PM   #19
If you have a Blue Ox WDH with sway control bars there's no need to unhitch before backing.
slipf18 is offline   Reply With Quote
Old 10-06-2015, 09:53 PM   #20
Kenny kustom's Avatar
Yup. Never unhooked.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
