Old 05-20-2016, 08:31 PM   #1
Help! Power from tow vehicle to trailer
Okay help me out. I have a 2013 f150. I connected all the required fuses required to supply power to trailer. But if my trailer battery is dead, I still don't have power to work the tongue jack. I'm forced to use a jumper box. I've been told that you should have full power from tow vehicle if connected. Am I doing something wrong? (Besides having a dead battery to begin with). I already added a battery shut off and a solar panel charger.
Bigmak304bs is offline   Reply With Quote
Old 05-20-2016, 08:34 PM   #2
Who Dares, Wins
doc73's Avatar
Make sure the fuse is not blown. There is prob a fuse or breaker (looks like a silver box about 1" x .5" with a black nub) on the one wire. Also my experience it a DEAD battery will not be charged by the TV because they use such a small wire it does not carry the needed current.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-20-2016, 08:36 PM   #3
Mr. Dan's Avatar
Most times there is an inline fuse between the battery and the jack... usually in a little plastic case/cocoon type thing. Check that fuse. If that doesn't help, loosen and tighten a bolt that holds the jack on the trailer. That's where the jack motor gets its ground.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 05-21-2016, 09:30 AM   #4
Turns out it was the fuse. Thx guys. Fuse looks weird. Almost like the connection on inside is corroded. I attached a closeup pic. Click image for larger version
Name:	ImageUploadedByForest River Forums1463840984.421373.jpg
Old 06-01-2016, 01:00 AM   #5
Yes, I know I'm late.
When I bought my TT new, the issue of a power tongue jack was my first concern so I bought a bottle jack that can be used in a pinch. Turns out the bottle jack can also be used to jack up the trailer in case I need to change a tire.
tosh99 is offline   Reply With Quote
power, tow vehicle, trailer
