Old 07-02-2016, 02:45 PM   #11
northstar1960's Avatar
Originally Posted by nomad297 View Post
How do we know what size the orifices are now? We have no idea what he is trying to do or what he is working with. I don't think he does, either.
Bruce
Correct ! the OP is going to blow himself up with what he's talking about. I'm outta of this thread won't be apart of someones death
northstar1960 is offline   Reply With Quote
Old 07-02-2016, 05:48 PM   #12
I think the type of burner that he has uses the one pound LP bottles that screw into to the stove shut off valve. This is a hi pressure system and runs right off the bottles with no regulator. I would go to your local LP distributor to buy right parts to convert it to a low pressure 11" system.
Hope This Helps Tim
TimVWulp is offline   Reply With Quote
Old 07-02-2016, 06:18 PM   #13
DouglasReid's Avatar
Wisest piece of advice
Originally Posted by TARVIDSON View Post
Stop at a full service propane supplier and get it straightened out correctly. It won't cost much and they can actually see what you have. I have been selling propane equipment for 30 years and from your comments you do not have the knowledge to be getting advice from a forum on this issue. About 2 minutes with a technician and you would have the knowledge you need. If your orifices need resizing they have the charts and orifice drills to do the job right.
X2! This is the wisest piece of advice you could possibly get. You are dealing with flammable gasses and pressure. Let those who are professionals in that business give you the benefit of their expertise! Whatever the cost is pales to insignificance to what a fire disaster could mean to you and your family!
2012 Wildcat Sterling 32RL, Maxxis 8008s Load rating E, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is online now   Reply With Quote
Old 07-02-2016, 06:42 PM   #14
TsnTexas's Avatar
The orifices are tiny, smaller than a pin. There is no regulator and it was previously used on an RV with dual regulator setup and yes, propane.
I'll look at the grill (also no regulator) to see what size orifice it has, but it's probably wise to find a propane dealer who will make recommendations.
Thanks all.
Sorry about the images being upside down.
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 07-02-2016, 06:52 PM   #15
I have the same stove in the picture. Yes, it has a connection that could be connected to one of the one pound bottles, but it does not have a regulator so I do not think you could use it that way safely. My stove requires 16 PSI.
Name:	Stove Label.jpg
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is online now   Reply With Quote
Old 07-02-2016, 07:05 PM   #16
TsnTexas's Avatar
That's the one, it has the same label. Only the connector on the hose is not one that fits the one pound bottles and I've already changed that out for the compatible disconnect for my camper. At any rate, I'll be headed to a propane dealer for advice.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 07-02-2016, 07:15 PM   #17
Normally a quick disconnect is a low pressure fitting and that stove will not run on low pressure, (which is what your camper uses). I could not find a regulator that was 16 PSI so I got one that was adjustable up to 30 PSI. So, I just set it about half and it works okay. Like I say, I have two regulators, (which is common if you are using anything requiring high pressure). The high pressure is the first one and has a Tee. I connect the outdoor store at the tee. The other side connects to the low pressure regulator.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Old 07-02-2016, 07:21 PM   #18
TsnTexas's Avatar
It could be that's what I'll wind up doing, I just had the thought that by changing the orifice for a low pressure stove might be the way to go if that's a possibility.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 07-02-2016, 07:24 PM   #19
Low pressure will not be enough to power that stove. You need the full 16 PSI. That is why that stove is so good and has way more heat than one of the indoor stoves. Also, there is much more adjustment to the flame.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Old 07-02-2016, 07:29 PM   #20
campingbaba's Avatar
A propane tech can get the office size and tell you the BTUs and than convert it to 11" wc with no problem . It's done all the time in the propane industry.
campingbaba is online now   Reply With Quote
pressure
