Old 07-02-2016, 07:39 PM   #21
AquaMan's Avatar
Easier to run a new line off one of the bottles than to start messing with changing orifices and such. I did this on my fifth wheel for a propane fire pit. Installed a tee in front of regulated line with a quick connect.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 07-02-2016, 08:04 PM   #22
TsnTexas's Avatar
Thanks again guys, I'll search out a propane tech and go from there.
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 07-02-2016, 11:57 PM   #23
northstar1960's Avatar
Originally Posted by TimVWulp View Post
I think the type of burner that he has uses the one pound LP bottles that screw into to the stove shut off valve. This is a hi pressure system and runs right off the bottles with no regulator. I would go to your local LP distributor to buy right parts to convert it to a low pressure 11" system.
Hope This Helps Tim
Those still have regulators . built into the control
northstar1960 is offline   Reply With Quote
Old 07-03-2016, 02:29 PM   #24
Originally Posted by Asrabbit View Post
I have the same stove in the picture. Yes, it has a connection that could be connected to one of the one pound bottles, but it does not have a regulator so I do not think you could use it that way safely. My stove requires 16 PSI.
how about a complete pic of the label . you will get a lot more then 16psi right out of a 20# bottle of propane . what's the name brand of this stove and wouldn't it just be cheaper to just by a good colman gas stove then try and retro fit this one
Old 07-03-2016, 07:23 PM   #25
I have mine working no issue.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
pressure
