Old 07-02-2016, 10:20 AM   #1
TsnTexas's Avatar
High pressure to Low pressure cooktop
I have picked up a two burner cooktop which I intended to use outdoors. It's a high pressure model and I've found a propane hose with the proper quick connect fitting that's on the camper. I'm not surprised that the flame is extremely low and so have a question: In order to convert the stove to low pressure is it just a matter of changing out the orifice on each of the two burners? I've removed them and see that the holes are extremely small. Am thinking about safety above all. Thanks.
2016 Rockwood 2504s
2016 Chevy 2500HD
TsnTexas is offline   Reply With Quote
Old 07-02-2016, 10:47 AM   #2
nomad297's Avatar
All you have to do is remove the regulator from your stove and get whatever you need to adapt to your new hose.
Bruce
Old 07-02-2016, 10:55 AM   #3
TsnTexas's Avatar
I should have mentioned that it doesn't have it's own regulator, but runs off the camper pressure which is regulated at the propane bottles up front. This quick connect is set up for the outdoor grill.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 07-02-2016, 11:29 AM   #4
nomad297's Avatar
How many inch water column is your stove designed to operate on propane with? Is it, indeed, a propane cooktop, or was it designed for natural gas?
Bruce
Old 07-02-2016, 11:43 AM   #5
northstar1960's Avatar
Bruce
NAT GAS would have a larger orifice because of the lower btus .
northstar1960 is offline   Reply With Quote
Old 07-02-2016, 11:47 AM   #6
Not sure what is meant by high pressure model . most will have a WC of between 5 and 13 max inches for use . would not call even 13 inches of WC high pressure that's less then a puff . you sure the unit does not have it's own regulator ? if not you can increase the size of the orifices with a drill bit just don't over do it
Old 07-02-2016, 11:50 AM   #7
nomad297's Avatar
How do we know what size the orifices are now? We have no idea what he is trying to do or what he is working with. I don't think he does, either.
Bruce
Old 07-02-2016, 12:18 PM   #8
TARVIDSON
Low or high pressure propane
Stop at a full service propane supplier and get it straightened out correctly. It won't cost much and they can actually see what you have. I have been selling propane equipment for 30 years and from your comments you do not have the knowledge to be getting advice from a forum on this issue. About 2 minutes with a technician and you would have the knowledge you need. If your orifices need resizing they have the charts and orifice drills to do the job right.
TARVIDSON is offline   Reply With Quote
Old 07-02-2016, 01:48 PM   #9
I have a high pressure outside stove and it has no regulator on the stove. To run the stove, I need a high pressure regulator, (the one on the camper is a low pressure one). To fix that, I put a Tee in the line with the high pressure regulator in front of the low pressure regulator. I routed the line from the high pressure regulator to the area where I wanted the connection to hook up a flexible line. I could not find a regulator with the correct pressure, 16 pounds, so I had to get an adjustable one.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is offline   Reply With Quote
Old 07-02-2016, 02:43 PM   #10
16 pounds ? what you running a blast furnace ? 16 pounds is beyond believable . I've worked on boilers large enough to heat small hotels and they run at about 11 inches of wc , you could hardly blow out a candle with 11 inches of WC. 16 pounds is absurd you running a restaurant with a grill to serve a cow ? i think you need to rethink what stove you have and what your doing
Old 07-02-2016, 02:45 PM   #11
Bruce
Correct ! the OP is going to blow himself up with what he's talking about. I'm outta of this thread won't be apart of someones death
Old 07-02-2016, 05:48 PM   #12
TimVWulp's Avatar
I think the type of burner that he has uses the one pound LP bottles that screw into to the stove shut off valve. This is a hi pressure system and runs right off the bottles with no regulator. I would go to your local LP distributor to buy right parts to convert it to a low pressure 11" system.
Hope This Helps Tim
TimVWulp is offline   Reply With Quote
Old 07-02-2016, 06:18 PM   #13
DouglasReid's Avatar
Wisest piece of advice
X2! This is the wisest piece of advice you could possibly get. You are dealing with flammable gasses and pressure. Let those who are professionals in that business give you the benefit of their expertise! Whatever the cost is pales to insignificance to what a fire disaster could mean to you and your family!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 07-02-2016, 06:42 PM   #14
TsnTexas's Avatar
The orifices are tiny, smaller than a pin. There is no regulator and it was previously used on an RV with dual regulator setup and yes, propane.
I'll look at the grill (also no regulator) to see what size orifice it has, but it's probably wise to find a propane dealer who will make recommendations.
Thanks all.
Sorry about the images being upside down.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 07-02-2016, 06:52 PM   #15
I have the same stove in the picture. Yes, it has a connection that could be connected to one of the one pound bottles, but it does not have a regulator so I do not think you could use it that way safely. My stove requires 16 PSI.
Name:	Stove Label.jpg
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Old 07-02-2016, 07:05 PM   #16
TsnTexas's Avatar
That's the one, it has the same label. Only the connector on the hose is not one that fits the one pound bottles and I've already changed that out for the compatible disconnect for my camper. At any rate, I'll be headed to a propane dealer for advice.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 07-02-2016, 07:15 PM   #17
Normally a quick disconnect is a low pressure fitting and that stove will not run on low pressure, (which is what your camper uses). I could not find a regulator that was 16 PSI so I got one that was adjustable up to 30 PSI. So, I just set it about half and it works okay. Like I say, I have two regulators, (which is common if you are using anything requiring high pressure). The high pressure is the first one and has a Tee. I connect the outdoor store at the tee. The other side connects to the low pressure regulator.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Old 07-02-2016, 07:21 PM   #18
TsnTexas's Avatar
It could be that's what I'll wind up doing, I just had the thought that by changing the orifice for a low pressure stove might be the way to go if that's a possibility.
2016 Rockwood 2504s
2016 Chevy 2500HD
Old 07-02-2016, 07:24 PM   #19
Low pressure will not be enough to power that stove. You need the full 16 PSI. That is why that stove is so good and has way more heat than one of the indoor stoves. Also, there is much more adjustment to the flame.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Old 07-02-2016, 07:29 PM   #20
campingbaba's Avatar
A propane tech can get the office size and tell you the BTUs and than convert it to 11" wc with no problem . It's done all the time in the propane industry.
campingbaba is offline   Reply With Quote
pressure
