Old 01-11-2016, 10:08 AM   #1
Holding Tank Dumping
What is the recommend process of proper dumping black and gray holding tanks.
FUZ
dsfuzzy is offline   Reply With Quote
Old 01-11-2016, 10:10 AM   #2
Head Rambler
Most dirty to cleanest. Dump the black first then the galley (if you have one) and then the grey. flushing each as you go.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 01-11-2016, 02:26 PM   #3
Here you go
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 Coachmen Freedom Express 292BHDS -- SOLD
2013 RAM 2500 CTD
2018 Prime Time Crusader 319RKT
Loraura is offline   Reply With Quote
Old 01-12-2016, 08:22 AM   #4
Fulltime family RVer
See if this link helps:
How to Dump RV Tanks (it's not so icky!)
ependydad is online now   Reply With Quote
Old 01-17-2016, 10:46 PM   #5
MNtraveler's Avatar
Between black and gray, use the black water flush if you have one. Then the gray will flush out all those remnants too from the exit area and flexible tubing.
PS: don't use your fresh water hose OR the potable water supply tap for the black water flush. Either use a black/gray hose or a garden hose you brought along that you will not use for potable water. Use the sewer flush/rinse tap they hopefully have at the dumping station for this and for rinsing the sewer hose.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
tank
