FR left a 3" hole through the floor at the low point water drain near the water heater. I fixed it and added valves to the pex piping. Not a big thing, just want to keep the mice and squirrels out of our new TT 220.
TV 2010 Saturn Outlook
TT 2014 Surveyor SP220RBS
Nice! We too discovered, after the intrusion of an uninvited guest, that there was a gaping hole alongside the exit for the black water pipe. The slipshod way they fitted the coroplast around the pipe appeared to be an afterthought.
K&L + the Wild Bunch TT: 2011 Rockwood 8293RKSS TV: 2019 Dodge 3500 SRW Crew HO CTD
Where did you find the valves for the low point drains? I want to add them to our trailer.
2020 Rockwood 2608BS
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
2021 Ford F-250 Super Duty
Sharkbite fittings (or similar brand) are a bit expensive, but are press-loc fittings sealed by an o-ring. Extremely easy to install. Looking at his installation ... very well done ... unless you have a PEX crimper tool plus the brass fitting cost, Sharkbite will run about the same price. I have them on my stool and kitchen sink lines in case of a failure especialy on the stool valve.
Tharmann ... your setup is a bit different than mine, did you just have caps on the ends of the fittings? My low point drain lines hang down below as yours does, but they are only the lines. I have the 2 shutoff valves about a foot up inside my conveniece center. Sorry to muddle your thread ... I just didn't think it thru very well before I responded.
