03-17-2017, 10:09 AM
Honda 3000 Inverter/RV air conditioner
Hello folks, I have just taken delivery of our new 2017 Catalina 283 RKS, and still trying to figure everything out, before we begin using it. I do have a question, and need some help.
Will a Honda 3000 Inverter be able to start and run the 15 K air conditioner? I have a chance to buy one quite reasonable. I have no pervious experience with any of this, and have much to learn.
Thanks to one and all for any help or suggestions.
Tom and Kathy
North Georgia
03-17-2017, 10:13 AM
Yes on the Honda! Youroo!!
03-17-2017, 10:18 AM
The eu3000i will start some 15k ACs, but not others. But either way a hard start kit for your AC would be beneficial and then the 3000 would handle all your needs.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
03-17-2017, 11:26 AM
You also need to consider the altitude that you will be at when running. A generator looses on average 7% efficiency per 1000 ft increase in elevation. So while this Honda 3000 may run the 15K at sea level, it probably wont at 6000 ft or higher.
2012 Ram 3500 Megacab SRW 6.7L Cummins
03-17-2017, 12:09 PM
With proper carburetor jetting the loss of generator efficiency is 3% per $1,000 feet.
03-17-2017, 12:35 PM
My stock Honda eu3000i will start and run my 15k AC just above 6000 FT.
Donald W.
2015 Coachmen Chaparral 29RKS 32'11" overall
2013 Ford F250 supercab 6.2L, 8'bed, 3.73
03-17-2017, 12:39 PM
I have a Rockwood 8288ws with a coleman mach 15k ac. My champion 3100 inverter gen runs it just fine.
03-17-2017, 12:58 PM
Me too on the Champion 3100 (inverter model), runs my 15k ac just fine. Local COSTCO here has them on shelf for $699. I'm a big Honda fan but...........
03-17-2017, 03:38 PM
I've run both the Honda eu3000i and the Champion 3100 inverter generators separately on my 15k AC unit. Both handled it well. The Honda was SLIGHTLY quieter, but both did well enough to run overnight.
Radi-cool Rik
03-17-2017, 05:07 PM
A 3000-watt generator may work but air conditioning manufacturers say you need a 3500-watt generator for a 15K air conditioning unit. You might consider the Yamaha EF3000iSEB. This version of the Yamaha generator has the “Boost” mode that allows the generator’s internal starting battery to supply the extra 500 watts of power to bring the air conditioner up to speed before returning a lower continuous run capacity.
Another option is to buy two 2000-watt generators and hook them in parallel when you need the added power to run your air conditioner. You can use just one generator to run most other appliances. Each 2000-watt generator weighs only 50 pounds so they are much easier to move. As for drawbacks, the 2000-watt units have a much shorter run-time than the 3000-watt units do (although there are extended run kits) and they don’t have electric start.
Weight was a major consideration for me. Two 50-pound units are much easier to maneuver than a single unit weighing nearly 145 pounds. The shorter runtime hasn’t been an issue for me.
Good luck.
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
03-17-2017, 08:38 PM
Just to confuse your further...
There are two issues.
First, what else can you run while running the AC on a genny. That is mostly a job of adding up the running amps of the stuff. You need to decide what needs to run along with the AC. Hot water on electric, hair dryer, microwave, charging a depleted battery, are all questionable. LED lights, refrigerator on propane, etc, no problem.
Second, the major problem with ACs is the current draw needed to start the unit. Actually you can "run" a 15k AC on a 2k genny, but you probably can't get it to start because of the extremely high initial draw. In some cases a hard start kit can help, but note that many newer AC units already have a hard start capacitor, and using the hard start actually increases the current draw, but spreads it out enough that the genny may not drop out due to overload.
Another option is an add on from MicroAir. They sell what they call an Easy Start. There are now quite a few users of these. Adding one of these to your AC will allow you to start and run your 15k AC on a 2k genny. For verification, there is a pretty robust thread on the Airstream forum called " Should I Keep My 2 X Honda 2000i Generators". It has one of the engineers from MicroAir answering questions. Note that any modifications to your AC unit may void the warranty. Upside to the EasyStart - once installed, it is there and works, there are also claims that it makes the AC run better - whatever that means. Downside - it costs about $350 and may void the AC warranty. FWIW, a hard start capacitor is probably less than $20.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
03-17-2017, 08:59 PM
I've run a 15K on the EU2000. Fan has to be on low speed. The generator is wide open. I didn't run it for long. I just wanted to see if it'd do it. I used to run my 13.5K quite a bit on the EU2000 tailgating for the first couple games when it was boiling hot outside.
03-18-2017, 09:56 AM
The Ginny came yesterday YaY
Our Champion 3400 with remoter and electric start came yesterday. It weighs about 100 lbs. From reading the specs it will start a 15K AC unit. Can't have Can't have the microwave on while turning on AC. It is still in the box, but I will post a video of it running in its beak in stage.
Have a good day.
Chuck & Denise + Pata, The Purple Princess Peanut, Ziggy the pole cat and Kazumba the parrot
2015 23 BD Gray Wolf
2008 Dodge Ram 2500 TX Edition 2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights 2018 1 trip, 93 nights
03-18-2017, 05:49 PM
Have a good day.
Well if you have problems running both, look into the EasyStart. [emoji57]
Al
03-19-2017, 08:14 AM
No experience on 15K and Honda 3000, other than what I've read. But I can tell you the start assist capacitor (called hard start) will help immensely. It helps even on shore power when we have voltage in campgrounds, as well. I would get one and install it.
It will not void warranty, since these AC units could come with one from the factory, of course it would be one bearing their brand name.
IMO they should install one on all units and simply charge $10 more. It will make them last longer and they certainly don't want to do that... failure one day past the warranty period seems to be their engineering goal.
WW
https://www.amazon.com/Supco-Relay-S...tart+capacitor
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
03-19-2017, 08:20 AM
I needed the hard start capacitor and a fan delay to reliably start my 15K Coleman Mach III with our Yamaha 3000iSeB (Boosted version) if it is really hot out. Will reliably start it when you don't need it
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-01-2017, 10:42 AM
Add the easy start. Very simple. [/IMG] This was two seasons ago. still works great. Must turn on only AC in breaker box
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 91, 2017 110
Days camped 2018 136
04-01-2017, 09:59 PM
Originally Posted by nodrawers
Add the easy start. Very simple.[/IMG] This was two seasons ago. still works great. Must turn on only AC in breaker box
There are a number of people claiming that a 2k gen will reliably start an run a 15k AC over on the Airstream forum. One of the MicroAir engineers has been posting a lot in one of the threads.
Al
04-01-2017, 10:01 PM
Don't know why you would want to do this, just buy two of 'em!!!
04-10-2017, 04:26 PM
My Honda EU2000I companion will run my 15K Dometic A/C with the fan on auto and my converter at the same time. My A/C is brand new (replaced under warranty last week) and does not have any additions.
The EU3000 should do fine for your a/c. As others have said, you probably won't be able to run electric hot water (Our trailer will trip a 20A breaker when the electric water heater kicks in while the A/C is running) or a microwave with it. But I'm betting the 3000 will run a/c, converter and a TV with no problems. Just force everything to use propane that can, such as your fridge, by flipping the breakers off.
To get the EU2000I to start my A/C, I turned all breakers off, started the generator, plugged in the camper, turned on the Main 30A breaker, then the 20A A/C breaker, then I adjusted the thermostat down to kick it on. Once it was running, I turned on the converter breaker and still didn't overload the generator.
2017 Cherokee Grey Wolf 26RL Dragged around by a 2004 Ford F-150 FX4 5.4L
2018 Nights Camped 05 : 35 total booked
2017 Nights Camped 37
2016 Nights Camped 23 (3 in popup)
Laissez les bons temps rouler!
