Old 09-09-2015, 06:46 PM   #11
arpipeliner's Avatar
Put the extra under a slide or camper. If it really bothered me get a step thing for the tire to step on for pickup and put on the camper tires with a stop to keep it from sliding off.
Seen a plastic coke/ pop flat used as a pallet to put them on in real wet areas.
arpipeliner is offline   Reply With Quote
Old 09-11-2015, 05:48 PM   #12
We use reflectors that are one a rod that can be put into the ground pretty easily and has metal loops on the road that can be used to put the hose and power cord.
drchef is offline   Reply With Quote
Old 09-11-2015, 05:49 PM   #13
We use reflectors that are one a rod that can be put into the ground pretty easily and has metal loops on the rod that can be used to put the hose and power cord.
Old 09-11-2015, 08:56 PM   #14
Driveway markers? Good idea. Thanx
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 09-11-2015, 09:05 PM   #15
dcheatwood's Avatar
If I have lots of slack cord after plugging in, I roll it up on the rear bumper of the fifth wheel. But my power plug is at the extreme rear on left side near the bumper. Do the same at home. May not keep all of it off the ground but some.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 09-13-2015, 07:23 AM   #16
Looks like a double shepherds hook will work. For anyone interested...
Old 09-16-2015, 12:09 AM   #17
Note that the cord organizer found at Home Depot is for 100 feet of 14/3 electrical cord. Electrical cord that is 14 gauge is rated for maximum 15 amps of electrical current.
Thurman is offline   Reply With Quote
Old 09-18-2015, 02:13 AM   #18
paulmac's Avatar
We use smaller shepherds hooks. They were originally for Halloween decorations that no longer work. They are about 3 feet off the ground when set up. Once hooked up I just loop the excess hose or electrical cable and hang them on the hook.
paulmac is offline   Reply With Quote
Old 09-18-2015, 02:36 AM   #19
Just a member
kandl's Avatar
Originally Posted by 220Chap View Post
I can't be the only one that wants to keep them clean!
You're not. That's why we carry rags/towels so that they can be wiped clean before being stowed.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 09-18-2015, 03:44 AM   #20
I'd rather keep them clean than clean them after they get dirty. Couple less things to do when breaking camp.
