Old 10-10-2010, 08:37 AM   #1
Hot Water Tank Bypass&FreshWater Overflow
I have a 2008 Georgtown 378ts. Does anyone know if it has a hot water tank bypass valve, and if so where is it located, and how do you get to it? Also the fresh water tank overflow tube located next to the L.P. tank, every time I make a left turn or the motorhome is leaning to the right. water comes out of it. I only carry 1/3 of a tank, any way to stop this?
grayfox2 is offline   Reply With Quote
Old 10-10-2010, 10:33 AM   #2
NWJeeper's Avatar
Did you try a search? This exact question was asked just last week. Yes there is a bypass, it is located behind the water heater, you have to lay on your back under the water heater and remove the round white disk in the bottom of the compartment to access the valve.
The venting issue has been covered here at great length please try using the search function.
Ed & Wendy
www.nwjeepn.com
